Tip:
Looking for settings for the Form Cure V1? Click here.
Formlabs updates post-curing settings periodically with new and improved materials. Download the latest PDF version (English only), and check for updated post-curing settings.
Select the material type and version to see the recommended Form Cure V2 time and temperature settings. To post-cure previous resin formulations with the Form Cure, use the recommended time and temperature for the closest resin version.
Over-curing is acceptable, unless otherwise stated. Increase the post-curing time for thick, bulky parts because they are slower to heat to the proper temperature.
For parts printed in a Formlabs resin for biocompatible applications, follow the post-curing steps in the relevant instructions for use or application guide. For Formlabs Fast Cure settings, see the support article Fast Cure time settings.
Tip:
Form Cure V2 settings
| Resin | Post-cure setting | Post-cure time | Post-cure temperature |
| Alpha Black Resin Alpha Clear Resin Alpha Fast Resin Alpha Grey Resin Alpha Model Resin Alpha White Resin |
Default | 1 min | No heat |
| Maximum strength | 5 min | 60 °C | |
| Alumina 4N Resin | N/A | N/A | N/A |
| BEGO™ VarseoSmileⓇ TriniQⓇ Resin | Full post-cure | Refer to the Compatibility Overview for washing and post-curing instructions for this resin. View the PDF at the attached link. | |
| BioMed Amber Resin | Full post-cure² | Refer to the Manufacturing Guide for washing and post-curing instructions for this resin. | |
| BioMed Black Resin | Full post-cure² | Refer to the Manufacturing Guide for washing and post-curing instructions for this resin. | |
| BioMed Clear Resin | Full post-cure² | Refer to the Manufacturing Guide for washing and post-curing instructions for this resin. | |
| BioMed Durable Resin V1 BioMed Durable Resin V1.1 |
| BioMed Flex 50A Resin11 (formerly BioMed Elastic 50A Resin) |
| BioMed Flex 80A Resin11 | Full post-cure² | Refer to the Manufacturing Guide for washing and post-curing instructions for this resin. | |
| BioMed White Resin | Full post-cure² | Refer to the Manufacturing Guide for washing and post-curing instructions for this resin. | |
| Black Resin V4/V4.1 | Default | 10 min | 60 °C |
| Black Resin V5 | Default | 1 min | No heat |
| Full cure | 5 min | 60 °C | |
| Castable Wax Resin Castable Wax 40 Resin |
N/A3 | N/A | N/A |
| Ceramic Resin | N/A¹ | N/A | N/A |
| Clear Resin V4 | Default | 5 min | 60 °C |
| Clear Resin V4.1 | Default | 7 min | 60 °C |
| Clear Resin V5 | Default | 1 min | No heat |
| Color Kit | Default | 10 min | 60 °C |
| Color Resin V5 | Default | 1 min | N/A |
| Full cure | 10 min | 60 °C | |
| Custom Tray Resin | Full post-cure² | Refer to the Manufacturing Guide for washing and post-curing instructions for this resin. | |
| Dental LT Clear Resin V2 | Full post-cure² | Refer to the Manufacturing Guide for washing and post-curing instructions for this resin. | |
| Dental LT Comfort Resin V1 Dental LT Comfort Resin V1.1 |
| Denture Base Resin V1 | Full post-cure² | Refer to the Instructions for Use for washing and post-curing instructions for this resin. | |
| Denture Base Resin V2 | Full post-cure² | Refer to the Manufacturing Guide for washing and post-curing instructions for this resin. | |
| Denture Teeth Resin | Full post-cure² | Refer to the Instructions for Use for washing and post-curing instructions for this resin. | |
| Draft Resin V2 | Better elongation | 5 min | No heat |
| Better UTS | 5 min | 60 °C | |
| Durable Resin V2 Durable Resin V2.1 |
Full post-cure4 | 12 min | 60 °C |
| Flexible 50A Resin (formerly Elastic 50A Resin V2) |
Full post-cure5 | 7 min | 70 °C |
| ESD Resin | Default | 10 min | 70 °C |
| Fast Model Resin | Default | 1 min | No heat |
| Flame Retardant Resin | Default | 5 min preheat 10 min post-cure |
100 °C |
| Flexible 80A Resin V1 Flexible 80A Resin V1.1 |
Default | 3 min | 60 °C |
| Flexible 80A Resin V2 | Default | Cycle 15: 5 min Cycle 2: 5 min |
Cycle 15: No heat Cycle 2: 80 °C |
| Grey Resin V4 Grey Resin V4.1 | Default | 10 min | 60 °C |
| Grey Resin V5 | Default | 1 min | No heat |
| Grey Pro Resin | Default | 8 min | 80 °C |
| High Temp Resin V2 | Default | 15 min | 80 °C |
| Thermal post-cure | 180 min | 160 °C | |
| IBT Resin | Full post-cure² | Refer to the Manufacturing Guide for washing and post-curing instructions for this resin. | |
| IBT Flex Resin | Full post-cure² | Refer to the Manufacturing Guide for washing and post-curing instructions for this resin. | |
| Model Resin V2 | Default | 10 min | 60 °C |
| Model Resin V3 | Default | 2 min | 60 °C |
| Permanent Crown Resin | Full post-cure² | Refer to the Instructions for Use [EN] [EU] for washing and post-curing instructions for this resin. | |
| Precision Model Resin | Default | 1 min | No heat |
| Premium Teeth Resin | Full post-cure² | Refer to the Manufacturing Guide for washing and post-curing instructions for this resin. | |
| PU Rigid 650 Resin | N/A | Refer to the support article Using PU Rigid 650 Resin. | |
| PU Rigid 1000 Resin | N/A | Refer to the support article Using PU Rigid 1000 Resin. | |
| Rigid 4000 Resin | Default | 6 min | 80 °C |
| Rigid 10K Resin V1 Rigid 10K Resin V1.1 |
Default | 3 min preheat 7 min post-cure |
80 °C |
| Silicone 40A Resin | Default | 10 min | 60 °C |
| Surgical Guide Resin | Full post-cure² | Refer to the Manufacturing Guide for washing and post-curing instructions for this resin. | |
| Temporary CB Resin | Full post-cure² | Refer to the Instructions for Use for washing and post-curing instructions for this resin. | |
| Tough 1000 Resin | Default | 12 min | 70 °C |
| Low warp | 12 min | No heat | |
| Tough 1500 Resin V1 Tough 1500 Resin V1.1 Tough 1500 Resin V2 |
| Default | 12 min | 70 °C | |
| Tough 2000 Resin V1 Tough 2000 Resin V1.1 |
Low warp | 7 min | No heat |
| Default | 7 min | 70 °C | |
| Tough 2000 Resin V2 | Low warp | 12 min | 40 °C |
| True Cast Resin V1 | Full post-cure | 3 min | N/A |
| White Resin V4 White Resin V4.1 |
| White Resin V5 | Default | 1 min | No heat |
1: Does not require post-curing. After washing, allow parts to fully dry before firing/casting.
2: This post-cure setting ensures that parts achieve both biocompatibility and optimum mechanical properties. Read the Manufacturing Guide for a full description of the workflow.
3: Does not require post-curing. Allow parts to fully dry before casting.
4: For parts printed with Durable Resin, the tensile modulus increases throughout the first hour of post-curing.
5: Place dry parts in a glass beaker (or other UV-transparent container) and completely submerge the parts in room temperature water.
Downloadable PDF
Formlabs updates post-curing settings periodically with new and improved materials. Download the latest PDF version (English only), and check for updated post-curing settings when using a new resin or revised formulation.
