Mechanical properties of selected Formlabs SLA resins
Below is data about the mechanical properties of selected Formlabs SLA resins. Use this data along with the information in Choosing the right material and the technical data sheet (TDS) for your selected material to pick a resin and evaluate your printed parts. If data for your material is not available, choose the closest comparable material and interpolate or extrapolate as necessary. For other requests, reach out to Formlabs Support or your sales representative.
Shore D and Shore A hardness of printed parts
Samples were printed on a Form 3 printer, post-cured as recommended for each material, and conditioned at 23 ℃ and 30% relative humidity for 48 hours.
Shore D hardness
ResinShore D hardness
Clear Resin V5
Black Resin V5
White Resin V5
Grey Resin V5
80 D
Clear Resin V4
Black Resin V4
White Resin V4
Grey Resin V4
82 D
Draft Resin V178 D
Draft Resin V285 D
Rigid 4000 Resin V189 D
Rigid 10K Resin V189 D
Grey Pro Resin V185 D
High Temp Resin V288 D
Tough Resin V581 D
Tough 2000 Resin V181 D
Tough 1500 Resin V176 D
Durable Resin V2.170 D
Durable Resin V270 D
Dental Model Resin V284 D
Surgical Guide Resin V176 D
Castable Wax Resin V171 D
Fast Model Resin79 D
ESD Resin90 D
Flame Retardant Resin75 D
Alumina 4N Resin70 D
Shore A hardness
ResinShore A hardness
Flexible 80A Resin80 A
Elastic 50A Resin V255 A
Silicone 40A Resin40 A
Representative stress-strain curves
The graphs below show representative curves only based on single samples of ASTM D638 Type 1 bars conditioned at 23 ℃ and 50% relative humidity. Actual results may vary depending on printed part conditioning, age of the resin, etc.
Click on a graph to expand it.
BioMed Amber Resin stress-strain curve
BioMed Amber Resin
BioMed Clear Resin stress-strain curve
BioMed Clear Resin
BioMed Elastic 50A Resin V1 stress-strain curve
Black Resin V5 stress-strain curve
Black Resin V5
Clear Resin V5 stress-strain curve
Clear Resin V5
Clear Resin V4.1 stress-strain curve
Clear Resin V4.1
Clear Resin V4 stress-strain curve
Clear Resin V4
Durable Resin V2.1 stress-strain curve
Durable Resin V2.1
Durable Resin stress-strain curve
Durable Resin V1
Elastic 50A Resin V2 stress-strain curve
Fast Model Resin stress-strain curve
Fast Model Resin
Flame Retardant Resin stress-strain curve
Flexible 80A Resin stress-strain curve
Flexible 80A Resin
Grey Resin V5 stress-strain curve
Grey Resin V5
High Temp Resin V2 stress-strain curve
High Temp Resin V2
PU Rigid 1000 Resin stress-strain curve
PU Rigid 1000 Resin
Rigid 4000 Resin stress-strain curve
Rigid 4000 Resin
Rigid 10K Resin stress-strain curve
Rigid 10K Resin
Tough 1500 Resin V2 stress-strain curve
Tough 1500 Resin V2
Tough 1500 Resin stress-strain curve
Tough 1500 Resin V1
Tough 2000 Resin stress-strain curve
Tough 2000 Resin
White Resin V5 stress-strain curve
White Resin V5
