Choosing the right resin
Formlabs offers a wide variety of SLA resins, covering a broad range of material properties and recommended applications. To help you choose the correct material for your use case, this article summarizes the available materials, their intended uses, and which Formlabs printers and resin tanks each is compatible with.
For other important information about Formlabs resins, see:
Tip:
For further guidance about materials, consult the Formlabs materials page.
Do not mix different resins (e.g., Clear Resin and Black Resin). Print settings for different resins are carefully calculated based on each resin’s material properties, color, and curing settings.
Resins designated as biocompatible must maintain separate accessories, including a dedicated resin tank, build platform, and finishing equipment.
Alpha Black Resin
Alpha Black Resin is a versatile general purpose resin for aesthetic, functional parts, combining fine detail and a rich, matte finish with fast print speeds and superior mechanical properties.
Recommended lifetime/shelf life: 24 months
Printers:
  • Form Studio 1
Resin tanks:
  • Form Studio 1 Tank (all)
Alpha Black Resin V1
Printer Available layer thicknesses(microns)
Form Studio 1 50, 100
Related articles:
Alpha Clear Resin
Alpha Clear Resin is a versatile transparent 3D printing resin for aesthetic, functional parts, combining an optically clear, neutral-color appearance with fast print speeds and superior mechanical properties.
Printers:
  • Form Studio 1
Resin tanks:
Alpha Clear Resin V1
Related articles:
Alpha Fast Resin
Alpha Fast Resin is a fast-printing general purpose resin with print speeds up to 130 mm/h, for iterative prototypes in minutes or print the entire build volume on Form Studio 1 in less than two hours.
Printers:
  • Form Studio 1
Resin tanks:
Alpha Fast Resin V1
Form Studio 1 150, 250
Related articles:
Alpha Grey Resin
Alpha Grey Resin is a versatile general purpose resin for aesthetic, functional parts, combining fine detail and a rich, matte finish with fast print speeds and superior mechanical properties.
Printers:
  • Form Studio 1
Resin tanks:
Alpha Grey Resin V1
Related articles:
Alpha Model Resin
Alpha Model Resin is a supremely detailed resin with a deep, fully matte, neutral surface that captures every detail, down to the finest crevices and textures.
Printers:
  • Form Studio 1
Resin tanks:
Alpha Model Resin V1
Form Studio 1 30, 50
Related articles:
Alpha White Resin
Alpha White Resin is a versatile general purpose resin for aesthetic, functional parts, combining fine detail and a rich, matte finish with fast print speeds and superior mechanical properties.
Printers:
  • Form Studio 1
Resin tanks:
Alpha White Resin V1
Form Studio 1 100
Related articles:
Alumina 4N Resin
Alumina 4N Resin is a high-density and high-purity technical ceramic 3D printing material with exceptional performance in extreme environments: thermally resistant, hard, abrasion-resistant, mechanically strong, and chemically inert.
Recommended lifetime/shelf life: 3 months (room temperature)
Refrigeration at -25–4 °C can add up to 12 months of additional shelf life, or 15 months total.
Printers:
  • Form 3/3+
  • Form 3B/3B+
  • Form 4/4B
Resin tanks:
  • Form 3 Tank V2.1
  • Form 4 Tank
Printer Available layer thicknesses (microns)
Form 3/3B/3+/3B+ 50
Form 4/4B 50
BEGO™ VarseoSmileⓇ TriniQⓇ Resin
Ceramic-filled material for highly accurate permanent restorative parts, provisional restorative parts, and denture teeth.
Recommended lifetime/shelf life: 36 months
Printers:
  • Form 4B
Resin tanks:
  • Form 4 Tank
Form 4B 50, 100
BioMed Amber Resin
Stiff, functionally strong medical-grade material for biocompatible parts that require short-term skin and mucosal membrane contact.
Printers:
  • Form 2
  • Form 3B/3B+
  • Form 3BL
  • Form 4B
  • Form 4BL
Resin tanks:
  • Form 2 LT
  • Form 3 Tank (all)
  • Form 3L Tank (all)
  • Form 4 Tank
  • Form 4L Tank
Form 2 50, 100
Form 3B/3B+ 50, 100
Form 3BL 100
Form 4B 50, 100
Form 4BL 50, 100
Related articles:
BioMed Black Resin
BioMed Black Resin is a medical-grade material designed for a wide range of end-use applications where performance, aesthetics and biocompatibility are critical. BioMed Black Resin is USP Class VI certified, and printed parts are validated for long-term contact with skin and short-term mucosal membrane contact.
Printers:
  • Form 2
  • Form 3B/3B+
  • Form 3BL
  • Form 4B
  • Form 4BL
Resin tanks:
  • Form 2 Standard
  • Form 2 LT
  • Form 3 Tank (all)
  • Form 4 Tank
  • Form 4L Tank
Form 2 50, 100
Form 3B/3B+ 50, 100
Form 3BL 50, 100
Form 4B 50, 100
Form 4BL 50, 100
Related articles:
BioMed Clear Resin
Medical-grade material designed for rigid, non-brittle, biocompatible parts that require long-term skin and mucosal membrane contact and for end-use medical devices.
Printers:
  • Form 2
  • Form 3B/3B+
  • Form 3BL
  • Form 4B
  • Form 4BL
Resin tanks:
  • Form 2 LT
  • Form 3 Tank (all)
  • Form 4 Tank
  • Form 4L Tank
Form 2 100
Form 3B/3B+ 100
Form 3BL 100
Form 4B 50, 100
Form 4BL 100
Related articles:
BioMed Durable Resin
BioMed Durable Resin is a clear material for applications requiring impact, shatter, and abrasion resistance.
Printers:
  • Form 3B/3B+
  • Form 3BL
  • Form 4B
  • Form 4BL
Resin tanks:
  • Form 3 Tank (all)
  • Form 4 Tank
  • Form 4L Tank
BioMed Durable Resin V1
Form 3B/3B+ 100
Form 3BL 100
BioMed Durable Resin V1.1
Form 4B 100
Form 4BL 100
Related articles:
BioMed Flex 50A Resin
BioMed Flex 50A Resin is a soft, elastic, medical-grade material for applications requiring comfort, biocompatibility, and transparency. This ISO 10993 and USP Class VI material is produced in an FDA-registered, ISO 13485 certified facility and can be used in applications with long-term skin and short-term mucosal membrane contact. Previously named BioMed Elastic 50A Resin.
Printers:
  • Form 3B
  • Form 3BL
  • Form 4B
  • Form 4BL
Resin tanks:
  • Form 3 Tank (all)
  • Form 4 Tank
  • Form 4L Tank
Form 3B 100
Form 3BL 100
Form 4B 100
Form 4BL 100
Related articles:
BioMed Flex 80A Resin
BioMed Flex 80A Resin is a firm, elastic, medical-grade material for applications requiring durability, biocompatibility, and transparency. This ISO 10993 and USP Class VI material is produced in an FDA-registered, ISO 13485 certified facility and can be used in applications with long-term skin and short-term mucosal membrane contact.
Printers:
  • Form 3B
  • Form 3BL
  • Form 4B
  • Form 4BL
Resin tanks:
  • Form 3 Tank (all)
  • Form 4 Tank
  • Form 4L Tank
Form 3B 50, 100
Form 3BL 100
Form 4B 100
Form 4BL 100
Related articles:
BioMed White Resin
BioMed White Resin is a medical-grade material designed for a wide range of end-use applications where performance, aesthetics and biocompatibility are critical. BioMed White Resin is USP Class VI certified, and printed parts are validated for long-term contact with skin and short-term mucosal membrane contact. BioMed White Resin is also certified for short-term contact with tissue, bone, and dentin.
Printers:
  • Form 2
  • Form 3B/3B+
  • Form 3BL
  • Form 4B
  • Form 4BL
Resin tanks:
  • Form 2 Standard
  • Form 2 LT
  • Form 3 Tank (all)
  • Form 4 Tank
  • Form 4L Tank
Form 2 50, 100
Form 3B/3B+ 50, 100
Form 3BL 50, 100
Form 4B 100
Form 4BL 100
Related articles:
Black Resin
Highly pigmented, opaque matte surface, great for printing small, intricate features.
Printers:
  • Form 1+
  • Form 2
  • Form 3/3+
  • Form 3B/3B+
  • Form 3L/3BL
  • Form 4/4B
  • Form 4L/4BL
Resin tanks:
  • Form 2 Standard
  • Form 2 LT
  • Form 3 Tank (all)
  • Form 4 Tank
  • Form 4L Tank
Black Resin V4
Form 1+ 25, 50, 100
Form 2 25, 50, 100
Form 3/3B/3+/3B+ 25, 50, 100
Form 3L/3BL 50, 100
Black Resin V4.1
Form 3L/3BL 50, 100
Black Resin V5
Form 4/4B 25, 50, 100
Form 4L/4BL 25, 50, 100
Related articles:
Castable Resin
Developed for clean burnout with direct investment casting.
Recommended lifetime/shelf life: 18 months
Printers:
  • Form 1+
  • Form 2
Resin tanks:
  • Form 2 Standard
  • Form 2 LT
Printers Available layer thicknesses (microns)
Form 1+ 25, 50, 100
Form 2 25, 50, 100
Castable Wax Resin
20% wax-fill material captures intricate features, offers smooth surfaces and high strength without post-curing. Developed for casting with zero ash content and clean burnout. Suitable for custom try-ons and direct investment casting.
Printers:
  • Form 2
  • Form 3/3+
  • Form 3B/3B+
  • Form 3L/3BL
  • Form 4/4B
  • Form 4L/4BL
Resin tanks:
  • Form 2 Standard
  • Form 2 LT
  • Form 3 Tank (all)
  • Form 4 Tank
  • Form 4L Tank
Form 2 25, 50
Form 3L/3BL 50
Form 4/4B 25, 50
Form 4L/4BL 50
Related articles:
Castable Wax 40 Resin
40% wax-fill and low expansion direct casting resin with superior castability, accommodates a wide range of design features such as stone holes and engraves.
Recommended lifetime/shelf life: 24–48 months
Printers:
  • Form 2
  • Form 3/3+
  • Form 3B/3B+
Resin tanks:
  • Form 2 LT
  • Form 3 Tank V2.1
Form 2 25, 50
Related articles:
Ceramic Resin
Composite, silica-filled resin that can be fired in a kiln or furnace to create a fully ceramic piece. This experimental Form X material requires more trial and error than other Formlabs products.
Recommended lifetime/shelf life: 12 months
Printers:
  • Form 2
Resin tanks:
  • Form 2 Standard
Form 2 50, 100
Clear Resin
Transparent, polishes to near optical clarity, great for internal channels and working with light.
Printers:
  • Form 1+
  • Form 2
  • Form 3/3+
  • Form 3B/3B+
  • Form 3L/3BL
  • Form 4/4B
  • Form 4L/4BL
Resin tanks:
  • Form 2 Standard
  • Form 2 LT
  • Form 3 Tank (all)
  • Form 4 Tank
  • Form 4L Tank
Clear Resin V4
Form 1+ 25, 50, 100, 200
Form 2 25, 50, 100
Form 3L/3BL 50, 100
Clear Resin V4.1
Form 3L/3BL 50, 100
Clear Resin V5
Clear Cast Resin
Translucent resin for creating sacrificial patterns for investment casting.
Printers:
  • Form 2
  • Form 3
  • Form 3B
  • Form 3L/3BL
  • Form 4/4B
  • Form 4L/4BL
Resin tanks:
  • Form 2 Standard
  • Form 2 LT
  • Form 3 Tank (all)
  • Form 4 Tank
  • Form 4L Tank
Form 2 50, 100
Form 3/3B 50, 100
Form 3/3BL 50, 100
Form 4/4B 50, 100
Form 4L/4BL 100
Related articles:
Color Kit
Opaque matte finish, 16 supported colors and potential for many more with opaque and matte finish. Colorful prints without finishing and painting.
Printers:
  • Form 2
  • Form 3/3+
  • Form 3B/3B+
  • Form 3L/3BL
  • Form 4/4B
  • Form 4L/4BL
Resin tanks:
  • Form 2 Standard
  • Form 2 LT
  • Form 3 Tank (all)
  • Form 4 Tank
  • Form 4L Tank
Form 2 25, 50, 100
Form 3L/3BL 100
Form 4/4B 50, 100
Form 4L/4BL 100
Related articles:
Color Resin
Choose any color to closely match final parts without painting, coating, or pigment mixing. Each order is custom-manufactured and quality checked, ensuring reliable results.
Printers:
  • Form 4/4B
  • Form 4L/4BL
Resin tanks:
  • Form 4 Tank
  • Form 4L Tank
Form 4/4B 100
Form 4L/4BL 100
Related articles:
Custom Tray Resin
Long-term biocompatible material formulated for manufacturing impression trays.
Printers:
  • Form 2
  • Form 3B/3B+
  • Form 3BL
  • Form 4B
  • Form 4BL
Resin tanks:
  • Form 2 LT
  • Form 3 Tank (all)
  • Form 4 Tank
  • Form 4L Tank
Form 2 200
Form 3B/3B+ 200
Form 3BL 200
Form 4B 100
Form 4BL 100
Related articles:
Dental LT Clear Resin
Designed for hard splints and retainers with high resistance to fracture and wear. Class IIa biocompatible.
Printers:
  • Form 2
  • Form 3B/3B+
  • Form 3BL
  • Form 4B
  • Form 4BL
Resin tanks:
  • Form 2 LT
  • Form 3 Tank (all)
  • Form 4 Tank
  • Form 4L Tank
Form 2 100
Form 3B/3B+ 100
Form 3BL 100
Form 4B 100
Form 4BL 100
Related articles:
Dental LT Comfort Resin
Dental LT Comfort Resin is engineered to be more flexible than Dental LT Clear Resin, making it more durable and more comfortable for patients.
Printers:
  • Form 3B/3B+
  • Form 3BL
  • Form 4B
  • Form 4BL
Resin tanks:
  • Form 3 Tank (all)
  • Form 4 Tank
  • Form 4L Tank
Dental LT Comfort Resin V1
Form 3B/3B+ 100
Form 3BL 100
Dental LT Comfort Resin V1.1
Printer Available layer thickness (microns)
Form 4B 100
Form 4BL 100
Dental SG Resin
Designed for surgical and pilot drill guides. Class I biocompatible resin (EN-ISO 10993-1:2009/AC:2010, USP Class VI).
Printers:
  • Form 2
  • Form 3B/3B+
Resin tanks:
  • Form 2 Standard
  • Form 2 LT
  • Form 3 Tank (all)
Form 2 50, 100
Form 3B/3B+ 50, 100
Related articles:
Denture Base Resin
Developed for biocompatible denture bases and teeth with fewer steps and less variability than traditional workflows. Class IIa biocompatible.
Printers:
  • Form 2
  • Form 3B/3B+
  • Form 4B
Resin tanks:
  • Form 2 Standard
  • Form 2 LT
  • Form 3 Tank (all)
  • Form 4 Tank
Form 2 50
Form 3B/3B+ 50
Form 4B 50
Denture Teeth Resin
Use to create biocompatible denture bases and teeth with fewer steps and less variability than traditional workflows. Class IIa biocompatible.
Printers:
  • Form 2
  • Form 3B/3B+
Resin tanks:
  • Form 2 Standard
  • Form 2 LT
  • Form 3 Tank (all)
Form 2 50
Form 3B/3B+ 50
Draft Resin
Fast print speed makes it ideal for same-day design iterations and printing bulky parts in less than eight hours.
Printers:
  • Form 2
  • Form 3/3+
  • Form 3B/3B+
  • Form 3L/3BL
Resin tanks:
  • Form 2 LT
  • Form 3 Tank V2/V2.1
Form 2 100, 200
Form 3/3B/3+/3B+ 100, 200
Form 3L/3BL 100, 200
Related articles:
Durable Resin
Similar physical properties to polypropylene (PP) or high density polyethylene (HDPE), where high elongation, deformation, or impact resistance are required.
Printers:
  • Form 2
  • Form 3/3+
  • Form 3B/3B+
  • Form 3L/3BL
  • Form 4/4B
  • Form 4L/4BL
Resin tanks:
  • Form 2 Standard
  • Form 2 LT
  • Form 3 Tank (all)
  • Form 4 Tank
  • Form 4L Tank
Durable Resin V2
Form 2 50, 100
Form 3/3B/3+/3B+ 50, 100
Form 3L/3BL 50, 100
Durable Resin V2.1
Form 4/4B 50, 100
Form 4L/4BL 50, 100
ESD Resin
Formlabs ESD Resin safely dissipates static buildup that can damage sensitive electronics, making it ideal for producing robust custom parts that comply with ESD safety standards.
Printers:
  • Form 3/3+
  • Form 3B/3B+
  • Form 3L/3BL
  • Form 4/4B
  • Form 4L/4BL
Resin tanks:
  • Form 4 Tank
  • Form 4L Tank
Form 3L/3BL 100
Form 4/4B 50, 100
Form 4L/4BL 50, 100
Fast Model Resin
Fast Model Resin is Formlabs’ fastest resin, capable of printing at speeds of over 100 mm per hour. Print dental models in minutes or large prototypes in less than two hours.
Printers:
  • Form 4/4B
  • Form 4L/4BL
Resin tanks:
  • Form 4 Tank
  • Form 4L Tank
Form 4/4B 100, 160, 200
Form 4L/4BL 100, 160, 200
Related articles:
Flame Retardant Resin
Flame Retardant Resin is a self-extinguishing and halogen-free material that performs well in environments with high temperatures or ignition sources.
Printers:
  • Form 3/3+
  • Form 3B/3B+
  • Form 3L/3BL
  • Form 4/4B
  • Form 4L/4BL
Resin tanks:
  • Form 4 Tank
  • Form 4L Tank
Form 3L/3BL 100
Form 4/4B 50, 100
Form 4L/4BL 50, 100
Related articles:
Flexible 50A Resin
Designed for applications requiring high elongation and high energy return. Use for prototypes that must bend, stretch, compress, and hold up to repeated cycles. Previously named Elastic 50A Resin.
Printers:
  • Form 3/3+
  • Form 3B/3B+
  • Form 3L/3BL
  • Form 4/4B
  • Form 4L/4BL
Resin tanks:
  • Form 4 Tank
  • Form 4L Tank
Form 3L/3BL 100
Form 4/4B 100
Form 4L/4BL 100
Related articles:
Flexible 80A Resin
Simulates 80A durometer rubber, high impact resistance and compression, great for ergonomic soft-touch grips.
Printers:
  • Form 2
  • Form 3/3+
  • Form 3B/3B+
  • Form 3L/3BL
  • Form 4/4B
  • Form 4L/4BL
  • Form Studio 1
Resin tanks:
  • Form 2 LT
  • Form 3 Tank (all)
  • Form 4 Tank
  • Form 4L Tank
Flexible 80A Resin V1
Form 2 50, 100
Form 3L/3BL 100
Flexible 80A Resin V1.1
Form 4/4B 100
Form 4L/4BL 100
Flexible 80A Resin V2
Form 4/4B 100
Form 4L/4BL 100
Form Studio 1 100
Grey Resin
Neutral and matte tone, great for showing off surface finish and for printing small, accurate features, photographs easily.
Printers:
  • Form 1+
  • Form 2
  • Form 3/3+
  • Form 3B/3B+
  • Form 3L/3BL
  • Form 4/4B
  • Form 4L/4BL
Resin tanks:
  • Form 2 Standard
  • Form 2 LT
  • Form 3 Tank (all)
  • Form 4 Tank
  • Form 4L Tank
Grey Resin V4
Form 1+ 25, 50, 100
Form 2 25, 50, 100, 160
Form 3/3B/3+/3B+ 25, 50, 100, 160
Form 3L/3BL 25, 50, 100
Grey Resin V4.1
Grey Resin V5
Form 4L/4BL 25, 50, 100, 150
Related articles:
Grey Pro Resin
Versatile material, resistant to deformation over time, suitable for concept modeling, functional prototyping, and parts intended for repeated use.
Printers:
  • Form 2
  • Form 3/3+
  • Form 3B/3B+
  • Form 3L/3BL
Resin tanks:
  • Form 2 LT
Form 2 50, 100
Form 3L/3BL 50, 100
Related articles:
High Temp Resin
HDT of 238 °C @ 0.45 MPa for V2 (FLHTAM02) and 289 °C @ 0.45 MPa for V1 (FLHTAM01), designed for static applications that experience high temperatures, including thermoforming, vulcanization, and electronics encapsulation.
Printers:
  • Form 1+
  • Form 2
  • Form 3/3+
  • Form 3B/3B+
  • Form 3L/3BL
  • Form 4/4B
  • Form 4L/4BL
Resin tanks:
  • Form 2 Standard
  • Form 2 LT
  • Form 3 Tank (all)
  • Form 4 Tank
  • Form 4L Tank
Form 1+ 25, 50, 100
Form 2 25, 50, 100
Form 3L/3BL 50, 100
Form 4/4B 50, 100
Form 4L/4BL 50, 100
Related articles:
IBT Flex Resin
IBT Flex Resin is a Class I material with enhanced flexibility, strength, translucency, and color, for seamless and precise transfer of orthodontic brackets and restorative composite materials.
Printers:
  • Form 3B
  • Form 3BL
  • Form 4B
  • Form 4BL
Resin tanks:
  • Form 3 Tank (all)
  • Form 4 Tank
  • Form 4L Tank
Form 3B 50, 100, 200
Form 3BL 100
Form 4B 50, 100
Form 4BL 100
Related articles:
IBT Resin
Designed for manufacturing biocompatible indirect bonding trays for orthodontic bracket placement.
Printers:
  • Form 2
  • Form 3B/3B+
  • Form 3BL
Resin tanks:
  • Form 2 LT
  • Form 3 Tank V2.1
Form 2 100
Form 3B/3B+ 100
Form 3BL 100
Related articles:
Model Resin
Highly accurate, formulated for printing crown and bridge models with removable dies.
Recommended lifetime/shelf life: 24 months (Model Resin V3), 18 months (Model Resin V2)
Printers:
  • Form 2
  • Form 3/3+
  • Form 3B/3B+
  • Form 3L/3BL
Resin tanks:
  • Form 2 LT
  • Form 3 V2.1
Form 2 50, 100
Form 3/3+ 50, 100
Form 3B/3B+ 50, 100
Form 3L/3BL 50
Permanent Crown Resin
Long-term biocompatible material developed for dental crowns, inlays, onlays, and veneers.
Printers:
  • Form 3B/3B+
Resin tanks:
  • Form 3 Tank (all)
Form 3/3+ 50
Related articles:
Precision Model Resin
Printers:
  • Form 4/4B
  • Form 4L/4BL
Resin tanks:
  • Form 4 Tank
  • Form 4L Tank
Form 4/4B 25, 50
Form 4L/4BL 50, 100
Premium Teeth Resin
A nano-ceramic filled Class II material designed for denture teeth and temporary full-arch implant-supported restorations (All-on-X appliances).
Printers:
  • Form 3B/3B+
  • Form 3BL
  • Form 4B
  • Form 4BL
Resin tanks:
  • Form 3 Tank (all)
  • Form 4 Tank
  • Form 4L Tank
Form 3B 50, 100
Form 3BL 100
Form 4B 50, 100
Form 4BL 50
Related articles:
PU Rigid 650 Resin
Parts printed with PU Rigid 650 Resin have extremely high impact strength and the physical properties of polyurethane, making them ideal for end-use applications that are intended to be exposed to harsh conditions. PU Rigid 650 and PU Rigid 1000 Resin have been evaluated as a skin contacting device in accordance with ISO 10993-1.
Printers:
  • Form 2
  • Form 3/3+
  • Form 3B/3B+
  • Form 3L/3BL
Resin tanks:
  • Form 2 LT
  • Form 3 Tank V2.1
Form 2 50, 100
Form 3L/3BL 100
Related articles:
PU Rigid 1000 Resin
Parts printed with PU Rigid 1000 Resin have extremely high impact strength and the physical properties of polyurethane, making them ideal for end-use applications that are intended to be exposed to harsh conditions. PU Rigid 650 and PU Rigid 1000 Resin have been evaluated as a skin contacting device in accordance with ISO 10993-1.
Printers:
  • Form 2
  • Form 3/3+
  • Form 3B/3B+
  • Form 3L/3BL
Resin tanks:
  • Form 2 LT
  • Form 3 Tank V2.1
Form 2 50, 100
Form 3L/3BL 100
Related articles:
Rigid 4000 Resin
Reinforced with glass for very high stiffness and a polished finish, highly resistant to deformation over time. Great for printing thin walls and features. Not suited for parts that must bend.
Printers:
  • Form 2
  • Form 3/3+
  • Form 3B/3B+
  • Form 3L/3BL
  • Form 4/4B
  • Form 4L/4BL
Resin tanks:
  • Form 2 LT
  • Form 4 Tank
  • Form 4L Tank
Form 2 50, 100
Form 3L/3BL 50, 100
Form 4/4B 50, 100
Form 4L/4BL 50, 100
Related articles:
Rigid 10K Resin
With a stiffness simulating that of glass and fiber-filled thermoplastics, Rigid 10K Resin is designed to maintain structural integrity under any condition.
Printers:
  • Form 2
  • Form 3/3+
  • Form 3B/3B+
  • Form 3L/3BL
  • Form 4/4B
  • Form 4L/4BL
Resin tanks:
  • Form 2 LT
  • Form 4 Tank
  • Form 4L Tank
Rigid 10K Resin V1
Form 2 50, 100
Form 3L/3BL 100
Rigid 10K Resin V1.1
Form 4/4B 50, 100
Form 4L/4BL 50, 100
Related articles:
Silicone 40A Resin
Silicone 40A Resin is a pure silicone, without added monomer or acrylate, which combines the material properties of cast silicone with the benefits of 3D printing
Printers:
  • Form 3/3+
  • Form 3B/3B+
  • Form 4/4B
Resin tanks:
  • Form 3 Tank (all)
  • Form 4 Tank
Form 4/4B 100
Related articles:
Soft Tissue Resin
Designed for simulation of the gingiva for dental implant modeling in customizable color pigments.
Printers:
  • Form 2
  • Form 3B/3B+
Resin tanks:
  • Form 2 LT
  • Form 3 Tank (all)
Form 2 50, 100
Related articles:
Surgical Guide Resin
Printers:
  • Form 2
  • Form 3B/3B+
  • Form 3BL
  • Form 4B
  • Form 4BL
Resin tanks:
  • Form 2 LT
  • Form 3 Tank (all)
  • Form 4 Tank
  • Form 4L Tank
Form 2 50, 100
Form 3B/3B+ 100
Form 3BL 100
Form 4B 50, 100
Form 4BL 50, 100
Temporary CB Resin
Long-term biocompatible material developed for dental crowns, bridges, inlays, onlays, and veneers.
Printers:
  • Form 2
  • Form 3B/3B+
Resin tanks:
  • Form 2 LT
  • Form 3 Tank (all)
Form 2 50
Form 3B/3B+ 50
Related articles:
Tough 1000 Resin
Simulates HDPE plastic. Great for parts requiring high impact strength, a low-friction surface, or the ability to bend, compress, or deform without cracking.
Printers:
  • Form 4/4B
  • Form 4L/4BL
Resin tanks:
  • Form 4 Tank
  • Form 4L Tank
Form 4/4B 50, 100
Form 4L/4BL 50, 100
Related articles:
Tough 1500 Resin
Simulates PP plastic. Great for functional prototyping of assemblies, snap-fits and hinges.
Printers:
  • Form 2
  • Form 3/3+
  • Form 3B/3B+
  • Form 3L/3BL
  • Form 4/4B
  • Form 4L/4BL
  • Form Studio 1
Resin tanks:
  • Form 2 LT
  • Form 3 Tank (all)
  • Form 4 Tank
  • Form 4L Tank
  • Form Studio 1 Resin Tank Pro
Tough 1500 Resin V1
Form 2 50, 100
Form 3L/3BL 50, 100
Tough 1500 Resin V1.1
Form 4/4B 50, 100
Form 4L/4BL 100
Tough 1500 Resin V2
Form 4/4B 50, 100
Form 4L/4BL 50, 100
Form Studio 1 100
Related articles:
Tough 2000 Resin
Simulates ABS plastic. Choose for applications that will undergo high stress and strain. Great for functional prototyping of assemblies, machining, and snap-fits.
Printers:
  • Form 2
  • Form 3/3+
  • Form 3B/3B+
  • Form 3L/3BL
  • Form 4/4B
  • Form 4L/4BL
Resin tanks:
  • Form 2 LT
  • Form 4 Tank
  • Form 4L Tank
Tough 2000 Resin V1
Form 2 50, 100
Form 3L/3BL 50, 100
Form 4/4B 50, 100
Tough 2000 Resin V1.1
Form 4/4B 50, 100
Form 4L/4BL 50, 100
Tough 2000 Resin V2
Form 4/4B 50, 100
Form 4L/4BL 50, 100
Related articles:
True Cast Resin
Use True Cast Resin for precision casting of intricate jewelry and complex engineering components up to 5 mm thick.
Printers:
  • Form 4/4B
  • Form Studio 1
Resin tanks:
  • Form 4 Tank
Form 4/4B 25, 50
Form Studio 1 50
Related articles:
White Resin
Neutral matte surface, slightly translucent when thin.
Printers:
  • Form 1+
  • Form 2
  • Form 3/3+
  • Form 3B/3B+
  • Form 3L/3BL
  • Form 4/4B
  • Form 4L/4BL
Resin tanks:
  • Form 2 Standard
  • Form 2 LT
  • Form 3 Tank (all)
  • Form 4 Tank
  • Form 4L Tank
White Resin V4
Form 1+ 50, 100
Form 2 50, 100
Form 3L/3BL 50, 100
White Resin V4.1
Form 3L/3BL 50, 100
White Resin 5V5
Form 4/4B 50, 100
Form 4L/4BL 50, 100
Related articles:
