Note:
If you change your print setting or switch the powder type associated with your printer, reprint the test print and redo the X/Y Scaling calibration.
Every Formlabs SLS printer goes through rigorous factory calibration. For applications that require high accuracy, Fuse 1 generation printers have a setting to optimize dimensional fit.
X/Y Scaling is an advanced calibration tool for Fuse 1 generation printers. Formlabs recommends adjusting the X/Y Scaling settings to improve dimensional accuracy and replicability for printed parts within a ±150 μm tolerance window.
Complete the following steps to tune your printer for fitment:
Printing the test file
Prepare your printer
Before printing the test file, ensure the printer is using the latest firmware and has a clean build chamber inserted.
Always reset the X/Y scaling settings to factory defaults before making any new adjustments. Failure to do so may result in inaccurate calibrations.
Prepare the model in PreForm
Note:
Post-processing the test print
Cooling the build chamber
SLS printed parts are sensitive to sudden and drastic temperature changes. After printing, the print job needs to cool in the build chamber to alleviate thermal stresses in the printed parts. Parts that are not allowed to properly cool may warp and are not suitable for X/Y Scaling calibration.
Formlabs recommends waiting at least 5 hours and 30 minutes before post-processing the build chamber with the X/Y Scaling test print.
Post-processing the printed parts
Note:
The X/Y Scaling test file also prints a small Formlabs butterfly above the test print. The Formlabs butterfly is not necessary for the calibration test and can be discarded.
Measure the X/Y Scaling test print
Measure the test print after it has been printed, cooled, and media-blasted. Use a set of calipers to determine the distance between each pair of measurement slots and input the values to the printer UI to accurately calibrate your Fuse 1 generation printer.
Measuring the test print
To ensure accurate readings:
Applying the new settings
Input the results from measuring the test print to the X/Y Scaling calibration tool on the printer’s touchscreen.
Note:
There is variation between different units, therefore it is necessary to print an X/Y Scaling test print for each printer and powder combination whose dimensional accuracy you want to adjust. Only apply the changed settings to the printer that was used to print the offset tool.
Calibrate the printer
Note:
The printer checks that values are within 1.5 mm of the nominal dimension in the model (30, 60, or 90 mm). The touchscreen displays a warning for any values that are out of range or missing. If any measurements are out of range:
Troubleshooting
If an error occurs while using X/Y Scaling, Formlabs recommends re-measuring the test print and inputting the new values into the printer touchscreen. If the error persists, please contact Formlabs Support or your authorized reseller.
