Cleaning the Fuse 1 generation recoater roller
The recoater distributes powder in an even layer as it moves across the print bed. Clean the recoater roller after 100 hours of printing to prevent divots and drag marks at the top surface of parts.
Human head (left-hand profile) wearing a mask
Caution:
Do not use compressed air or an air gun to clean the print enclosure, build chamber, or any other component. Mobilizing loose powder increases the risk of unintentional inhalation or ingestion.
Required supplies
Estimated time required: 5 minutes
Supplies:
  • Particulate filtering respiratory protection (N95 or better)
  • Non-reactive nitrile gloves
  • Safety glasses
  • Non-abrasive microfiber cleaning cloths
  • Ethanol (optional)
  • Alconox (optional)
Cleaning the recoater roller
Remove the build chamber, and move the roller to the middle of the printer. Wipe the surface of the roller with a microfiber cleaning cloth. For a deeper clean, wet the cloth with ethanol.
Step 1: Remove the build chamber
It is easier to clean the full surface of the roller when there is no build chamber in the printer.
Step 2: Move the recoater to the middle of the printer
Use Motor Moves to move the recoater to the middle for easier access to the roller surface.
  1. On the touchscreen, navigate to Maintenance > Motor moves
  2. Touch and hold the appropriate directional toggle that will move the recoater out into the middle of the printer.
The Fuse 1 generation recoater moved to the center of the build chamber
Step 3 (optional): Soak the recoater roller
Inspect the recoater roller. If there is only a light coating or buildup on the recoater roller, proceed to step 4. Otherwise,if there is significant buildup, remove it from the printer and soak it before wiping:
  1. Uninstall the recoater roller following the steps in the guide for replacing the Fuse 1 generation recoater roller.
  2. Soak the recoater roller in Alconox for several minutes.
  3. Wipe the recoater roller with a microfiber cleaning cloth. Repeat the soak if necessary. Ensure that the roller is fully dry after it is clean.
  4. Reinstall the recoater roller, again following the steps in the guide for replacing the Fuse 1 generation recoater roller.
Step 4: Wipe the recoater roller
Using a microfiber cleaning cloth, wipe the full surface of the roller. If there is hardened debris on the surface, wet the cloth with ethanol for a deep clean.
The recoater does not need to be manually homed after cleaning. It will automatically home during pre-print.
Note:
If there are deep scratches or burrs on the recoater roller, replace the recoater roller to avoid part defects. The component is available for purchase on the Formlabs Store. Follow the steps in the guide Replacing the Fuse 1 generation recoater roller to install the new recoater roller.
