Fuse X1 Is Now Shipping: Build Your Quote, Calculate Cost per Part, See Accuracy, and Explore the Workflow
Fuse X1 is now shipping, ahead of the delivery timeline we originally announced. The first customers who ordered it already have their systems up and running, and we're commissioning dozens more every week.
A Fuse X1 ecosystem at GoEngineer in Salt Lake City, Utah.
Two Fuse X1 ecosystems at  i-SOLIDS in Houston, Texas.
To help you decide whether Fuse X1 is right for your business, we’re making it easier than ever to see the whole picture before you buy. Pricing for the complete ecosystem is now public, a new interactive calculator estimates cost per part and throughput using your own files, and new resources cover accuracy, the end-to-end workflow, and the technology behind it all.
Order now to secure delivery in Q1 2027 in North America, Europe, or APAC.
Watch the Complete Fuse X1 Workflow
Our new workflow video follows Fuse X1 from file to finished part, showing an industrial workflow that anyone on your team can run. It covers every step: preparing builds in PreForm, printing, breaking out parts and recovering powder with Fuse Sift X1, cleaning and finishing with Fuse Blast, mixing powder with the Mix Kit X1, and best practices for safe operation.
Build Your Quote With Transparent Pricing
Pricing for industrial 3D printers is often hard to pin down without a lengthy sales process. We think you should be able to see the real number from the start.
Fuse X1 and all of its accessories and services are now available in the Formlabs store, with every price listed upfront. Build your quote to configure the ecosystem that fits your production needs and see exactly what it will cost. When you’re ready, contact our sales team directly to finalize your order or talk through your options.
Calculate Cost per Part and Throughput With Your Own Files (Beta)
comparison in the cost per part calculator
An example comparison in the calculator: for the same part, Fuse X1 fits 1,889 parts per build at $0.54 per part, compared with 265 parts at $0.83 on Fuse 1+ 30W and 797 parts for an estimated $2.12 on HP MJF 5620 Pro.
The price of the system is only part of the story. In production, what matters is how much each part costs and how many good parts you can make in a week. Our new interactive calculator answers both questions using your own files.
Upload your parts and compare Fuse X1 with Fuse 1+ 30W, or with other SLS and MJF systems such as the HP MJF 5620 Pro and EOS P3 NEXT. You can also add a custom profile for your current production method, or for any other solution you’re considering.
Cost per part is calculated from every input that drives it: hardware, labor, materials, consumables, service, and facilities. The calculator also models throughput, including print time, cooling time, and post-processing, and lets you adjust it to your actual weekly schedule, such as working hours and number of shifts, so the results reflect how your shop really runs.
Want to understand what’s behind those numbers? Packing density, or how much of the build volume you can fill with parts, is one of the biggest drivers of cost per part in powder bed fusion. In How Packing Density Drives Cost per Part: Fuse X1 vs. HP Jet Fusion 5600 Series, we break down why MJF systems are typically limited to around 8–10% packing density by volume, how Fuse X1 packs builds at 30% or more, and what that gap means for material waste, throughput, and the cost of every part you make.
Fuse X1 Delivers on Dimensional Accuracy, Repeatability, and Yield
Throughput and cost only matter if your parts meet spec. Fuse X1 is engineered for consistency across its full 61.5-liter build volume, and Adaptive Thermal Control is designed to keep results reliable even in densely packed builds.
We tested that across 14 builds on four Fuse X1 printers. At a process capability of Cpk 1.33, the standard threshold for a capable production process, Fuse X1 holds ±0.26–0.33 mm in X/Y and ±0.34–0.67 mm in Z for features up to 80 mm. With no part-specific scaling, 93% of parts had all 18 measured dimensions within ±0.3 mm or ±0.5%, whichever is larger.
Platform
Builds / Total parts
Cpk 1.33 tol. XY [mm]
Cpk 1.33 tol. Z [mm]
Yield, ±0.3 mm or ±0.5%
Yield, ±0.2 mm or ±0.3%
IT grade XY / Z (Cpk 1.33)
Fuse X1
14 / 467
0.26–0.33
0.34–0.67
93% (96%)
70% (79%)
IT13–IT14 / IT14
EOS P396
2 / 328
0.24–0.30
0.55–0.97
30% (97%)
3% (72%)
IT12–IT14 / IT15
HP Jet Fusion 5620
3 / 377
0.48–0.60
0.62–1.22
44% (79%)
11% (38%)
IT14–IT15 / IT15–IT16
We also benchmarked Fuse X1 against an EOS P396 and an HP Jet Fusion 5620 using the same witness-cube geometry. Fuse X1 is on par with both in X/Y accuracy and is the most accurate of the three in Z at every size range. The difference shows most clearly in part yield: against the same ±0.3 mm / ±0.5% criterion, 93% of Fuse X1 parts passed, compared with 44% on the HP Jet Fusion 5620 and 30% on the EOS P396.
Understand the Technology Behind Fuse X1
In case you missed it, our technology deep dive goes under the hood to show how Fuse X1 combines:
  • A massive 61.5-liter build volume
  • Adaptive Thermal Control for consistent, dense builds
  • AI-powered Print Intelligence for improved reliability
  • Automated powder transport and recovery
  • Fuse Sift X1 for fast, efficient depowdering
  • Fuse Blast for automated cleaning and polishing
  • PreForm software for streamlined production workflows
The result: more parts per build, less hands-on labor, and up to 50% lower cost per part, all in a system designed to fit into your existing facility.
Bring Production In-House With Fuse X1
Fuse X1 brings large-format industrial SLS within reach of teams that have been outsourcing parts, running smaller systems at capacity, or priced out of legacy industrial machines. And now you can see what the system costs, what each part will cost, and how it performs before you commit.
Systems are shipping now, and new orders are scheduled for delivery in Q1 2027 in North America, Europe, and APAC. Build your quote to configure your Fuse X1 ecosystem, or contact our sales team to discuss your application with an SLS expert.
