Danger:
IPA is flammable. Keep containers closed, and keep out of the reach of children.
Proactive maintenance is key to keep your Form Auto printing successfully. Keep the machine and the surrounding environment clean and free of liquid resin. Clean any liquid resin using paper towels dampened with soap and water. If necessary, dampen the paper towels with isopropyl alcohol to fully remove the resin.
Danger:
Schedule of maintenance
Follow the maintenance schedule to inspect, clean, and maintain your Form Auto.
| Procedure | Frequency |
| Update the firmware | When indicated by Formlabs |
| Clean the build platform print surface | Weekly |
| Fully clean the build platform | When changing resin type |
| Clean the printer and Form Auto |
| Clean the part release bin | When you empty the part release bin |
| Clean the part release enclosure |
Updating Form Auto firmware
When you update the firmware on the printer attached to the Form Auto, the printer automatically updates the firmware on the Form Auto if a new version is available. Keep your printer’s firmware up to date to get the latest bug fixes and improved functionality.
Cleaning after a resin spill
In case of a resin spill, clean the printer following Formlabs recommendations. If the liquid resin is contained within the printer, no further action is needed to clean the Form Auto.
Warning:
Resin may cause skin irritation or an allergic skin reaction. Wear gloves when handling liquid resin or resin-coated surfaces. Wash skin with plenty of soap and water. Do not use solvents like IPA to clean resin off skin.
In case of a severe resin spill on the Form Auto:
Cleaning the part release bin
Clean the part release bin after emptying it.
To clean the part release bin:
Cleaning the part release enclosure
Clean the part release enclosure when you change resins to prevent liquid resin from contaminating the surface of your printed parts. Fully clean the build platform at the same time to prevent resin contamination.
To clean the part release enclosure:
Alternatively:
Do not place the part release enclosure directly in the Form Wash L wash bucket—doing so may damage the Form Wash L impellers.
Planned maintenance procedures
Be sure to also follow the schedule of maintenance for the printer installed on the Form Auto.
If you encounter any mechanical issues, ensure that there are no obstructions blocking the cover, part release mechanism, part release enclosure, or any other moving parts on the Form Auto. If the machine is free of obstructions and the mechanical issues persist, contact Formlabs Support or your authorized reseller.
