Warning:
Maintain and clean each resin tank using Formlabs instructions to maximize tank performance and to ensure consistent, high-quality prints over a tank’s lifetime. Only use approved materials and processes to clean the resin tank and film.
Warning:
Tip:
Inspect the resin tank for damage and wear between prints and before storing the resin tank.
Cleaning after a failed print
A failed print may leave small, partially-cured pieces of resin floating in the tank or hard cured resin stuck to the film in the base of the tank. Remove debris from the tank film by hand or by printing a cleaning sheet. The cleaning sheet prints as a thin layer across the resin tank, binding cured and partially cured resin into a single piece. The cleaning sheet can then be removed from the tank along with the failed print.
Printing a cleaning sheet
The cleaning sheet is a thin part that prints directly on the resin tank film and is perfect for removing print failures or hard to find debris from the resin tank. It should take approximately 2–15 seconds to print, depending on the material. All Formlabs resins have predefined cleaning sheet print durations.
With firmware 1.15.0 and later, you can also set a custom cleaning sheet printing time on a per-resin basis. This can be useful if you are printing with custom print settings or a third-party material via the Print Settings Editor and Open Material Mode. It can also help if you have had issues with the Formlabs default print times in the past and want to optimize your workflow.
For best results, Formlabs recommends using a cleaning sheet holder when printing a cleaning sheet.
To print the cleaning sheet holder:
To begin printing the cleaning sheet:
Removing a completed cleaning sheet
The cleaning sheet causes other bits of cured resin to adhere and become caught in a single part. After the cleaning sheet has finished printing, it’s time to remove all cured resin from the resin tank.
To remove the cleaning sheet from the tank:
Tip:
If the cured resin is not easily extractable, consider reprinting the cleaning sheet. The extra curing time creates a stronger cleaning sheet that can lift larger debris cured strongly on the film.
Form 4 and Form 4L generation resin tanks contain two wear strips, which are mounted above the tank film and protect the film from the mixer. Printing and removing a cleaning sheet may detach one or both of the wear strips. Clean the wear strips of resin and reinsert into the resin tank.
Tip:
To conserve resin, you can drain the uncured resin coating the cleaning sheet through a filter back into the tank.
Removing cured resin manually
Use the plastic scraper that comes with the Finish Kit or a similar tool to remove individual pieces of cured resin from the resin tank. Apply minimal force to remove the cured resin. Avoid using the corners of the tool to dig under the print.
Do not use a metal tool to inspect the Form 4 resin tank or remove cured resin from the tank. Metal tools may damage the tank film, leading to failed prints or a resin spill.
Cleaning the resin tank
Keep the resin tank—especially the top and underside surfaces of the film—clean and free of cured resin and other debris to ensure print quality and extend the lifetime of the printer.
Cleaning the wear strips
Form 4 and Form 4L generation resin tanks contain two wear strips, which are mounted above the tank film and protect the film from the mixer. Inspect the wear strips regularly to ensure no debris is caught underneath the tank film.
To clean the resin tank wear strips:
Cleaning the tank film
The bottom of the Form 4 and Form 4L resin tank is made of a transparent film. Light shines upward through this film to cure the liquid resin in the tank. Any scratches or debris on the tank film will cause defects on printed parts. Resin can cure inside large flaws in the film, creating deposits that can cause errors and print failures. When interacting with the Form 4 or Form 4L resin tank, take care to avoid scratching, denting, or puncturing the film.
Do not use paper towels or any other abrasive cleaners to clean the resin tank film. Doing so can scratch the tank film and cause print failures.
To clean the tank film or film underside:
Cleaning the resin tank exterior
Do not allow liquid resin to become caught or to cure between the two layers of the tank film. Resin trapped between the film layers renders the resin tank unusable.
To clean the resin tank exterior:
Cleaning the plastic tank scraper
Clean the plastic tank scraper after each use to remove excess liquid resin and prevent contamination.
To clean the tank scraper by hand:
To clean the tank scraper using the Form Wash:
Filtering the resin (optional)
After removing the primary print failure, inspect the resin and tank for other small fragments. While the mixer keeps the print area clear during printing, clean resin and optical transparency in the bottom of the resin tank are always the best way to ensure quality prints.
If you see or feel any resin cured in your tank, it's essential to remove debris by cleaning the tank or the next print will fail. Use a paint filter with a "Fine" or 190 micron mesh size to thoroughly strain liquid resin.
Cleaning the Form 4L resin tank debris catchers
Print failures often leave behind small pieces of cured resin that can easily lead to future print failures or surface defects on your parts. The Form 4L resin tank debris catchers help prevent this by filtering out these pieces of cured resin and sequestering them at the sides of the resin tank, away from the print area.
Clean out the debris catchers if you notice large, loose debris or when they are more than halfway full.
Note:
Early Form 4L resin tanks do not have debris catchers and cannot be retrofitted to use them. If your resin tank does not have debris catchers, be sure to promptly remove any debris from a previous failed print.
To clean the Form 4L resin tank debris catchers:
Installing the Form 4L resin tank debris catchers
Reinstall the debris catchers after cleaning out any debris. To install the Form 4L resin tank debris catchers:
Correctly-installed debris catcher
Incorrectly-installed debris catcher
When correctly installed, the tab on the debris catcher sits in the notch in the tank frame. The debris catcher does not hang over the resin tank wall.
When installed incorrectly, the tab on the debris catcher does not sit in the notch in the tank frame. The debris catcher hangs over the resin tank wall.
