Starting a print (SLS)
Before you begin
After purchasing your printer, select the necessary consumables that best suit your work environment and use case.
Step 1: Set up PreForm
After setting up the printer, download PreForm:
Step 2: Prepare a model in PreForm
Once the latest version of PreForm is installed on your computer:
Step 3: Transfer a file from PreForm to the printer
After setting up your model in PreForm, choose a printer to run the print job:
Step 4: Prepare the nitrogen system
Fuse 1+ 30W
The Fuse 1+ 30W has the option to use nitrogen as an inert gas atmosphere in the print chamber. The inert nitrogen atmosphere prevents the oxidation of plastic powder. See the support article Choosing the right powder for a list of which powders should be printed using nitrogen. If you are running your print with an inert gas atmosphere, prepare the nitrogen system and enable N2 Mode on the printer.
Fuse X1
The Fuse X1 requires nitrogen for printing. The inert nitrogen atmosphere prevents the oxidation of plastic powder. See the support article Connecting a nitrogen supply to the Fuse X1 for detailed instructions.
Step 5: Start a print on the printer
After transferring the print job, confirm the print job on the printer’s touchscreen to start the print.
Note:
When starting a print with a new build chamber, the printer reads the build chamber as Unassigned. The build chamber automatically assigns itself to the powder type of the credits loaded onto the printer.
Step 6: Manage usage and data in Dashboard
