After inspecting and testing all five plaques, determine the correct offset temperature that best matches the above criteria, by using the temperature offsets listed on the plaques. This offset can then be manually set on the machine.
If the 725 µm piece cannot be pressed out of the coldest (−2 °C) plaque, the bed temperature is still too hot. Decrease the bed temperature offset on the printer to −3 °C and run the tool again. This will test offsets ranging from −1 °C to −5 °C.
If the 600 µm circle pops out of the hottest (+2 °C) plaque, the bed temperature is still too cold. Increase the bed temperature offset on the printer to +3 °C and run the tool again. This will test offsets ranging from +5 °C to +1 °C.
After the second round, select the offset corresponding to the plaque that best meets the acceptance criteria. If none of the plaques meet the criteria, contact Formlabs Support for further assistance.
