Using BioMed Durable Resin
BioMed Durable Resin is a clear material for applications requiring impact, shatter, and abrasion resistance. This USP Class VI material is made in an FDA-registered, ISO 13485 facility and can be used in applications for long-term skin (>30 days) and short-term tissue, bone, and dentin contact (<24hrs).
alttext
Recommended for:
  • Patient-specific instruments
  • Single-use instruments
  • End-use devices and components requiring biocompatibility and impact resistance
BioMed Durable Resin prints at 100 microns.
 BioMed Durable ResinBioMed Clear Resin
Ultimate tensile strength (MPa)29.152
Tensile modulus (MPa)9942080
Elongation at break (%)3312
Durometer/Shore Hardness75D78D
Flexural modulus (GPa)0.640.23
IZOD Impact strength (J/m)9835
To learn more about the performance properties of Formlabs resins, refer to the library of material properties data sheets.
Printing with BioMed Durable Resin
  1. Open a model.
  3. Orient according to the manufacturing guide.
  4. Generate supports.
Washing
Follow the part washing recommendations in the manufacturing guide for the clearest and best possible results. Improper washing can lead to suboptimal mechanical and biocompatibility properties.
Post-curing requirements
Follow the post-curing recommendations in the manufacturing guide for the clearest and best possible results. Improper post-curing can lead to suboptimal mechanical and biocompatibility properties.
Additional resources
