Using the Bulk Firmware Updater in Fleet Control
The Bulk Firmware Updater in Fleet Control lets you manage and update firmware versions across multiple printers on Dashboard.
If the printer is idle and not running a print job, the updates start automatically. If the printer is running a print job, the update starts once the print job is complete.
alttext
Note:
The Bulk Firmware Updater is available in Dashboard.
Only administrators of a printer group have access to the Bulk Firmware Updater. The Bulk Firmware Updater is not visible to printer group members. Change the roles of members in a printer group to allow others to manage printer firmware.
Manage update preferences for an individual printer with Dashboard
Enabling automatic updates on a printer
  1. Open Dashboard.
  2. Click Printers. The Printers screen appears.
  3. Click the Manage updates button in the printer group heading. The firmware management panel appears and outlines all your printers and their respective firmware versions.
  4. Select the firmware of the printer you wish to update. A dropdown menu appears, letting you choose between Automatic updates and Manual update.
  5. Select Automatic updates. The printer’s entry in the Changes column updates to reflect your selection.
  6. Click Apply to save changes.
Manually updating a single printer’s firmware
  1. Open Dashboard.
  5. Hover your cursor over Manual update. A list appears that displays the printer’s five most recent firmware versions.
  6. Select the firmware version you wish to upload to the printer. The printer’s entry in the Changes column updates to reflect your selection.
  7. Click Apply to save changes.
Manage update preferences for multiple printers with the Bulk Firmware Updater
Enable automatic updates for your entire fleet or push a manual update to update all of your printers to their latest firmware version.
Enabling automatic updates on multiple printers
  1. Open Dashboard.
  4. In the printer header click Set all to. A dropdown menu appears, letting you choose between Automatic updates and Manual update.
  5. Select Automatic updates. The Changes column updates to reflect your selection.
Manually updating multiple printers to their latest firmware
  1. Open Dashboard.
  5. Hover your cursor over Manual update and select To latest firmware. The Changes column updates to reflect your selection.
Different printer models (e.g., Form 3, Form 3L, or Fuse 1) have different firmware versions, so you cannot manually select a single firmware version for a mixed set of printers. To update a set of printers to a specific firmware version, filter the printer group by printer type.
When adjusting firmware update settings, you can use all available filters with the exception of the Printer Group filter. For example, you can filter the printer group to all Form 3 printers to narrow your list of printers. Click Apply to save your changes. After clicking Apply, updates start immediately if applicable. Click Cancel to revert all changes.
Note:
Filtering does not revert previous unapplied changes. If you change the firmware versions for your Fuse printers, then filter for Form 3 printers, both Fuse and Form 3 printer firmware changes take effect when you click Apply.
