What should I use to clean my Fuse Sift?
Keep the Fuse Sift clean to ensure maximum functionality throughout the lifetime of the machine. Clean the Fuse Sift's components with the appropriate tools and solvents, depending on what the component is made of. Check the table below to learn about the compatibility of cleaning tools or chemicals with different components of the Fuse Sift.
| TOOL OR SOLVENT | Use it for | Do not use it for |
| Brush | Sifter mesh | Vent filter |
| Compressed air Gas duster | Hard-to-reach areas Fresh powder hopper Used powder hopper Outer surfaces | Build chamber Build chamber enclosure Sifter mesh Vent filter |
| Non-abrasive microfiber cloth Vacuum | Area surrounding the sifter mesh Build chamber Build chamber enclosure Fresh powder hopper Outer surfaces Part extraction tools Parts basket Surface grate Tool shelf Used powder hopper Vent filter Walls Workspace | Sifter mesh |
| Paper towels Water | Outer surfaces Sifter gasket Sifter mesh turnbuckles | Sifter mesh Vent filter |
