Introducing Form Studio 1: Professional Resin 3D Printing, Starting at $699
15 years ago, Formlabs was founded on a mission: to build the tools that make it possible for anyone to bring their ideas to life. Form 1 took stereolithography off the factory floor and put it on a desktop. Four generations later, Form 4 is the best-selling professional resin 3D printer in the world — ten times faster than Form 1, far more reliable, and trusted by over 90% of Fortune 500 hardware companies.
But we've only been delivering on part of that mission. Almost everyone printing on a Formlabs machine is a professional.
Resin printing produces parts with detail, material properties, and speed that nothing else on a desktop can match. Until now, though, getting those parts at an accessible price point meant accepting real trade-offs: messy workflows, finicky settings, unreliable results, and materials with genuine health risks.
Form Studio 1 is our answer. We took 15 years of engineering and packed it into the world's most affordable professional resin 3D printer — fast, safe, reliable, open, and, with Alpha Resins and the VOC Extractor, the first and only UL GREENGUARD Gold Certified resin 3D printer. Form Studio 1 is now available, starting at $699. A limited Founder’s Edition in aqua, teal, and violet colorways is available while supplies last.
Founder’s Edition Form Studio 1 3D printers in teal, aqua, and violet.
Blazing Fast: Most Prints in Under Two Hours
Harness industry-leading print speeds for every application. Form Studio 1 averages 40 mm/h across materials, which puts most prints under two hours.1 With Alpha Fast Resin, speeds reach 130 mm/h — you can produce a finished, functional part in less time than an FDM printer needs to calibrate and lay down its first layers.2
This Raspberry Pi enclosure was printed in 8 minutes in Alpha Fast Resin on Form Studio 1
This Raspberry Pi enclosure was printed in 8 minutes in Alpha Fast Resin on Form Studio 1.
Printing this fast doesn't just save time. It changes how you design, iterate, and build — you can test three revisions in an afternoon instead of three days.
Every part of Form Studio 1 is engineered for speed and print success. 28 high-powered LEDs deliver 6 mW/cm² at the print plane. We also introduced a new second-generation release texture with more airflow that reduces peel forces so parts separate from the film faster. The new tank film uses a novel polymer that combines improved durability with very low bonding to resin. The improvements allow for high print speed and best-in-class print success rate.
Prints with Formlabs materials start immediately thanks to automatic resin dispensing and fast resin heating. This means no manual pouring of resin or topping off, for a clean, intuitive workflow.
1 Typical print time using 80th percentile print height (53 mm), 100 μm layer height, and most materials.
2 Max print speed using Alpha Fast Resin and 250 μm layer height based on actual print times from a collection of test parts covering common engineering, product design, miniatures, and art applications.
Razor-Sharp Details and Premium Materials
Form Studio 1 delivers sharp edges and smooth surfaces through 35 µm pixels — 30% finer than Form 4 — plus anti-aliasing, a highly collimated backlight, and resins formulated specifically for its light engine with validated print settings.
This robot is powered by two harmonic drives — the high-end transmissions used in industrial robots. They're difficult to manufacture and typically very expensive, because the key mechanical components are usually precision-machined stainless steel. Every mechanical part on this robot, including the critical flex spline, was printed on Form Studio 1 in Alpha Clear Resin.
Nine Formlabs resins are fully supported at launch:
Every Formlabs material ships with validated print settings in PreForm. Our optimization engineers tune every setting against hundreds of real user models, so you import your file, pick your material, and press print. No trial and error.
Lastly, because Form Studio 1 is open, you can print third-party materials too.
Six New Alpha Resins
Most resins on the market make you compromise. Aesthetics, toughness, cost — pick two. Alpha Resins were formulated from scratch to take advantage of the Form Studio 1 light engine, and they don't ask you to choose.
Every Alpha Resin is low-odor, independently certified for long-term skin safety, and the first 3D printing resins certified to UL GREENGUARD GOLD. Pricing starts at $29/L.
3d printed object using Alpha Resins
Alpha Grey, White, and Black Resins
  • Stunning, precise parts with rich matte color, crisp fine features, and smooth, dimensionally accurate surfaces
  • Print speeds up to 40 mm/h at 100 μm
  • Engineering-grade performance that exceeds the strength and toughness of ABS-like resins and filaments: 43 MPa ultimate tensile strength, 34% elongation at break.
Buy Now
Alpha clear resin printed part
Alpha Clear Resin
  • Optical clarity and neutral color with crisp fine features and smooth, dimensionally accurate surfaces, for transparent parts that fit together.
  • Same speed and engineering-grade performance as Alpha Grey, White, and Black.
Buy Now
Alpha model resin 3d printed figures
Alpha Model Resin
  • A deep, fully matte, neutral surface that captures every detail — down to the finest crevices and textures — and takes paint evenly.
  • Ultra-fine accuracy resolves the finest features and holds dimensional accuracy for multi-part models that assemble precisely.
  • Built to be handled: thin features flex instead of snapping, so finished models survive painting, transport, and the occasional drop.
Buy Now
Alpha Fast resin 3d printed object
Alpha Fast Resin
  • Print speeds up to 130 mm/h — small components in minutes, an entire build volume in under two hours.
  • Validated print settings deliver speed without compromising print success.
  • Engineering-grade performance exceeding ABS-like resins and filaments: 46 MPa ultimate tensile strength, 34% elongation at break.
Buy Now
Which Alpha Resin Should I Use?
Alpha Model Resin
Alpha Grey Resin
Alpha Fast Resin
Best for
Best fine features and matte finish
Balance of speed and aesthetics
Fastest printing
Primary layer height
50 μm
100 μm
150 μm
Print speed
15 mm/h
40 mm/h
90 mm/h
(up to 130 mm/h at 250 μm)
Recommended for
Scale models, figurines, sculptures, and busts
Concept models, form-and-fit prototyping, jigs, and fixtures
Rapid prototyping, jigs, and fixtures
High-Performance Formlabs Resins on Form Studio 1
drivetrain printed in Tough 1500 Resin
Tough 1500 Resin V2 stands up to demanding, high-impact applications. The drivetrain of this RC car is printed in Tough 1500 Resin.
Air blower printed in Flexible 80A resin
Flexible 80A Resin has such a high tear strength and elongation at break that you can make parts you'd never thought were possible with 3D printing.
print patterns for casting
Print patterns for casting — from intricate jewelry to complex, functional, metal parts — with True Cast Resin.
Safe, Worry-Free Indoor Printing
When we started developing Form Studio 1 and Alpha Resins, we set out to build the world's safest resin 3D printing ecosystem. Resin printing today is something of a Wild West, and many printers and materials on the market carry significant health and safety risks.
The First UL GREENGUARD Gold Certified 3D Printer
UL GREENGUARD is a third-party certification that addresses indoor air quality.
Form Studio 1 is the first and only resin 3D printer to be UL GREENGUARD Gold Certified when printing Alpha Resins with the VOC Extractor.
UL GREENGUARD Gold certification means a product has been tested for chemical emissions, with its manufacturing process reviewed, and shown to have minimal impact on indoor air quality. It's UL's stricter certification, designed for sensitive environments where children, older adults, and other vulnerable people spend extended time — like schools, daycares, hospitals, and nurseries. This means you can print comfortably at home or at work, with no special ventilation or makeshift enclosure needed.
How the VOC Extractor Works
Volatile organic compounds (VOCs) have a high vapor pressure at room temperature, which makes them airborne. They're responsible for the scent of everything from perfume to 3D printing resin. Some VOCs are odorless, and some are sensitizing agents that can cause allergic reactions after repeated exposure.
An optional accessory, the VOC Extractor is an active filtration device that attaches to Form Studio 1. A fan pulls VOC-laden air from the printer through a hose and pushes it through an activated carbon filter set that absorbs the VOCs. The result is safer, lower-odor printing suitable for confined spaces like homes and classrooms.
In internal testing, we placed TVOC sensors in sealed boxes with different printers and ran two-hour prints. A third-party printer running a general-purpose resin produced high VOC levels. Alpha Resins on Form Studio 1 measured far lower. With the VOC Extractor, VOC levels barely changed compared to the baseline.
The VOC Extractor is also compatible with Form 4 and Form 4B, but it has only been tested and GREENGUARD Gold Certified with Form Studio 1 printing Alpha Resins.
Safe Materials, Not Just a Safe Printer
Formlabs develops and manufactures a wide range of FDA-compliant medical materials, some cleared for long-term use in the mouth. We apply those same testing standards to Alpha Resins. All Alpha Resins are made and tested at our factory in Ohio, USA.
Alpha Resins:
  • Use only low-odor chemicals for a more pleasant printing environment.
  • Use vetted ingredients. No chemicals with known acute toxicity or known long-term effects on organ or reproductive health. In liquid form, their skin irritation potential is comparable to household laundry detergent — tested to the same standard used for cosmetics and personal care products.
  • Are certified skin-safe. Parts printed with Alpha Resins on Form Studio 1 and post-processed following Formlabs’ recommended guidelines are certified for long-term (>30 days) skin contact, in accordance with ISO 10993, the same standard used for Medical Devices. This means printed parts are non-cytotoxic, non-skin irritants, or non-skin sensitizers.
We ran industry-standard cytotoxicity tests on printed parts from both Alpha Resins and competitor materials. A fully washed and cured Sunlu ABS-like part scored 4/4 for cytotoxicity — it killed nearly the entire cell culture. Alpha Grey, tested identically, scored 1/4, leaving cells indistinguishable from the untreated control.
cytotoxicity test results
We're publishing results for every resin we test so anyone can review them — and we want your input on what to test next. We'll publish results for the most-requested resins.
How Alpha Resins Compare
Formlabs Alpha Resins
Third-Party Budget Standard
Third-Party Budget ABS-Like
Third-Party Premium Low-Cost
Formlabs General Purpose
Price
$29–39
$12–20
$20–30
$29–59
$79–99
Examples
Elegoo, Anycubic, Sunlu Standard & 8K
Sunlu / Anycubic ABS-Like, Siraya Tech Fast
HeyGears, Ameralabs
Safety
✓ Not cytotoxic
✓ Long-term skin-safe
✓ UL GREENGUARD GOLD
✗ Printed parts cytotoxic
✗ Contains components like ACMO, hazardous to inhale or contact
• Not tested for skin safety
• Not tested for GREENGUARD
✓ Not cytotoxic
Print speed
40 mm/h @ 100 μm (Fast: up to 130 mm/h @ 250 μm; Model: ~15 mm/h @ 50 μm)
~15 mm/h @ 50 μm
~15 mm/h @ 50 μm
~15 mm/h @ 50 μm
45 mm/h @ 100 μm (Fast Model: up to 100 mm/h @ 200 μm)
Aesthetics
Great
Good/Great
Medium
Great
Medium
Toughness (Elongation at Break)
Good (34%)
Poor (3–6%)
Good (30–50%)
Great
Medium (15%)
Reliability
Great (98% print success)
Poor (70–85% print success)
Poor
Medium
Great (98.7% print success)
Odor
Low
High
High
Medium
Low
Tough, aesthetic, accessible, and UL GREENGUARD GOLD Certified — with Alpha Resins, you don't have to compromise.
Reliable Printing
Stop coming back to failed prints. Formlabs SLA 3D printers have a 99% print success rate when printing with Alpha Resins. Whether you’re printing a part for a client, a same-day order, or a part for your class in two hours, achieve the parts you need when you need them.
Validated settings that balance print speed, part aesthetics, and support removal, combined with intelligent systems and automated diagnostics, ensure reliable printing. Five control systems monitor temperature, resin level, print force, and print status throughout every print. Plus, you can remotely monitor your prints and manage your printer from anywhere; an integrated camera shows print status via Dashboard and the new Formlabs Mobile App.
Open: Print Any Resin You Want
Form Studio 1 ships open. You get access to Formlabs materials and to third-party resins.
Two resin tanks are available:
form studio 1 resin tank
Resin Tank
form studio 1 resin tank pro
Resin Tank Pro
The Form Studio 1 Resin Tank is strong and flexible, built for fast print speeds and fine feature resolution, with a film that reduces peel forces. However, it's optimized for specific chemistries, like Alpha Resin, other resins can degrade it rapidly, leading to leaks.
The Form Studio 1 Resin Tank Pro is built for compatibility with a wide range of resins. Its chemically resistant dual-layer film supports third-party materials without risk of degradation or leakage. The trade-off is print speed, so we recommend the standard tank whenever your material allows it.
Both resin tanks have a lifespan of 75,000+ layers (approximately 200 prints at 37 mm tall, at 100 µm layer height). Every tank comes with a reusable lid that protects resin from light and debris when it's out of the printer, and lets you stack tanks for compact storage. If you run multiple resins, we recommend keeping a dedicated tank per material, so switching is as simple as swapping in a new cartridge and its matching tank.
The Technology Behind Form Studio 1
For Form Studio 1, we built on the technology behind Form 4. At its core is the Low Force Display (LFD) Print Engine, with updated subsystems:
  • Automatic Resin Handling. Hands-free, fast, accurate dispensing with minimal waste and glove-free material swapping. Unlike printers that require manual pouring, Form Studio 1 dispenses and refills tanks in minutes while monitoring cartridge volume and verifying that the cartridge and tank materials match, so you'll never start a print you can't finish.
  • Intelligent Control Systems. Five integrated systems precisely control temperature, resin level, print forces, and print status, including a camera and lighting for remote monitoring, troubleshooting, and time-lapse video.
  • Flexible Film Resin Tanks. Designed to reduce the forces exerted on parts during printing.
  • Release Texture V2. An updated proprietary microtextured optical film surrounded by perimeter channels that increase airflow and passively reduce print forces — faster prints without compromising surface finish, fine feature resolution, accuracy, or reliability.
  • Light Processing Unit Studio 1 (LPU S1). Precisely masks light from the backlight unit into the shape of each layer. Long-lasting at 750K–1.5M layers of consistent performance, with an aluminum frame, top surface coating, and smart software to protect against accidental damage. When replacement is needed, a tool stored inside the printer makes it easy.
  • Backlight Unit. 28 LEDs with a plano-convex lens array deliver uniform, fully collimated light at 6 mW/cm² across the entire print plane. Most low-cost resin printers use a single COB light source with a Fresnel lens, producing uneven exposure and poorly collimated light that strikes pixels at an angle. The result: crisp details and clean edges no matter where parts sit on the build platform.
We test every component extensively — from the optics and motion system to the tanks — to make sure each part of the printer stands up to demanding use.
Effortless Part Removal With Build Platform Flex
Tired of scraping parts off a build platform? Form Studio 1 Build Platform Flex with Quick Release Technology removes parts from the print surface in seconds, without tools. Just squeeze, and they come right off. Recommended for almost all prints, it eliminates the risk of damaging your part and streamlines your workflow.
Build Platform Flex comes with the Flex Package or can be purchased separately.
Compact Post-Processing With Form Studio Wash+Cure
After printing, resin parts must be post-processed. Form Studio Wash+Cure is a compact, all-in-one washing and curing station that completes the Form Studio 1 ecosystem, enabling affordable post-processing of your resin 3D prints.
The Form Studio Wash+Cure has two modes in one compact desktop unit.
Form Studio Wash+Cure washing
Washing mode. All resin 3D printed parts need washing to remove residual resin. Form Studio Wash+Cure agitates IPA or alternative solvents* around parts for thorough, efficient cleaning. When washing is done, simply raise the internal basket out of the solvent to let parts air-dry and avoid over-soaking, which can warp prints.
Form Studio Wash+Cure curing
Curing mode. Open the cover, remove the bucket, install the turntable, and you're ready. Using 405 nm light, Wash+Cure completes the chemical reaction started during printing, boosting strength, toughness, heat resistance, and creep resistance, and leaving a harder, less tacky surface. Parts printed in Alpha Resins are skin-safe once post-processed per Formlabs guidelines.
*Form Wash+Cure is compatible with IPA, TPM, and Resin Washing Solution.
Form Studio 1 workflows are also compatible with Form Wash and Form Cure.
Learn to Print in 10 Minutes
Form Studio 1 is easy to use, with intuitive workflows that take less than 10 minutes to learn.
The Form Studio 1 Ecosystem Workflow
PreForm project setup
Upload your file and set up your print in PreForm
  • Import your model into PreForm
  • Pick your printer and material — each comes with validated print settings
  • Set up your print with one-click print, or manually orient and add supports
form studio 1 build platform setup
Set up your printer
  • Insert and lock a clean build platform
  • Insert your resin cartridge and flip the air vent cap
  • Insert a tank and lock both side latches
  • Automatic resin dispensing makes the workflow clean and reliable, while making it easy to switch materials.
Form studio 1 workflow washing
Remove your prints and wash
  • Pop parts off the build platform in seconds, no tools required, with Build Platform Flex
  • Wash your parts in the Form Studio Wash+Cure basin
  • Let your parts air dry completely
Form Studio 1 workflow curing
Cure parts and finish
Service Plan to Keep You Running
Form Studio 1 comes with a one-year warranty. Cover your Form Studio 1 with a worry-free service plan for $9.99/month or $99/year until cancelled.
Form Studio 1 Warranty
Form Studio 1 Pro Service Plan
One-year hardware warranty
Unlimited repairs for LPU damage and spills ($150 printer replacement, $50 LPU replacement)
Email support with Formlabs experts
Phone support from Formlabs experts
Continued warranty until cancellation
Start Resin Printing With Form Studio 1
Until now, accessible resin 3D printers have come with compromises: mess, finicky settings, dangerous materials, and unreliability. Form Studio 1 changes this, answering the call from around the world for a professional tool at an accessible price, built for safe 3D printing. With Form Studio 1, Formlabs is further committing to our mission to build the tools that make it possible for anyone to bring their ideas to life.
Form Studio 1 is now available worldwide. Three limited runs of Form Studio 1 3D printers in Founder’s Edition colors — aqua, teal, and violet – are available while supplies last.
