Alumina 4N Resin Quick Start Guide
Alumina 4N Resin has unique printing and post-processing requirements compared to other Formlabs resins.
To safely handle resin, follow Formlabs general safety and handling recommendations and read and understand the safety data sheet (SDS).
At room temperature, Alumina 4N Resin has a shelf life of three months. Formlabs recommends refrigeration at -25–4 °C to add up to twelve months of additional shelf life.
Required resources
Made by Formlabs:
Form 3 generation
  • Stainless Steel Build Platform or Build Platform 2
  • Alumina 4N Resin mixer
Form 4 generation
  • Build platform or Flex Build Platform
All compatible printers
  • Compatible Formlabs SLA printer with up-to-date firmware
  • PreForm software (most recent version)
  • Alumina 4N Resin cartridge
  • Ceramic Wash Solution
  • Form Wash, Form Wash L, or Finish Kit
Made by third parties:
  • Kiln capable of at least 1600° C
  • Alumina setter plates
  • Additional burnout kiln and refrigerator highly recommended
Preparing your model
Follow the instructions in the support article Design guidelines for Alumina 4N Resin. Alumina 4N Resin, like other ceramics, shrinks when fired. Design parts using CAD software to accommodate 21.8% horizontal shrinkage and 26% vertical shrinkage.
  1. Open a model.
  3. Orient to preserve fine details.
  4. Generate supports.
Printing with Alumina 4N Resin
Form 3 generation
Formlabs strongly recommends calibrating your printer's resin level sensor and Z-axis. Access these features by tapping Settings > Maintenance > Calibration.
  1. Shake the Alumina 4N Resin cartridge for a few seconds to ensure the resin is mixed completely.
  2. Place the mixer that came with the cartridge in the resin tank following the process shown on the tank sticker.
  3. Prefill the tank with approximately 300 mL of Alumina 4N Resin.
  4. Monitor the printer during initialization for any issues until the printing screen appears. Note that print times for Alumina 4N Resin are considerably longer than the print times for other resins.
If there are any issues during the print, check the tank for any debris and remove it.
Form 4 generation
Printing with Alumina 4N Resin on a Form 4 generation printer requires no special calibration, checks, or additional hardware.
  1. Shake the Alumina 4N Resin cartridge for two minutes to ensure the resin is mixed completely.
  2. Insert the resin cartridge and press open the vent cap.
  3. Insert and secure a resin tank and mixer.
  4. Insert and secure a build platform.
  5. Start your print.
alttext
Post-processing
Wash the printed parts for 2 minutes in Ceramic Wash Solution. Do not allow Alumina 4N Resin parts to come into contact with water or IPA, as this will cause cracking. Use a separate wash bucket to prevent loose ceramic particles from adhering to non-Alumina 4N parts. Minimize the amount of time the printed part is covered in Ceramic Wash Solution to prevent cracking.
Gently blow dry parts with air, focusing the airflow on corners and crevices. Wipe accessible surfaces dry with a paper towel. Aggressive drying rates can cause cracking.
Once parts are removed from the build platform, the build platform and any peripherals can be cleaned with IPA or soapy water to remove liquid resin. Remove rafts using a spatula and a hammer. Take care to avoid injury from sudden movements, and wear safety glasses.
Parts printed with Alumina 4N Resin are easy to sand in their green state. Dry sand the parts or use the Ceramic Wash Solution as a lubricant.
Firing Alumina 4N Resin
Read the support article Printing and firing Alumina 4N Resin for detailed instructions.
Dry parts for 24 hours prior to firing. Green parts can be stored or shipped as necessary.
Fire parts on setter plates rated for a minimum of 1700 °C. Formlabs recommends the two furnace schedule below, but several options for firing exist.
Two furnace schedule (recommended)
Two furnace schedule for firing parts printed in Alumina 4N Resin
TIME STEP (min) TOTAL TIME (hr) END TEMP °C RATE °C/min
0 0 25
160 2.67 105 0.5
60 3.67 105 0
100 5.33 115 0.1
240 9.33 115 0
400 16 155 0.1
240 20 155 0
200 23.33 175 0.1
240 27.33 175 0
300 32.33 205 0.1
240 36.33 205 0
300 41.33 235 0.1
360 47.33 235 0
750 59.83 310 0.1
360 65.83 310 0
525 74.58 415 0.2
120 76.58 415 0
585 86.33 1000 1
965 102.42 35 1
0 102.42 25
70 103.58 200 2.5
600 113.58 600 0.67
360 119.58 1150 1.53
440 126.92 1510 0.82
120 128.92 1510 0
485 137.00 1200 -0.64
750 149.50 0 -1.6
Single furnace schedule
Single furnace schedule for firing parts printed in Alumina 4N Resin
0 0 25
160 2.7 105 0.5
300 7.7 150 0.15
180 10.7 150 0
1400 34.0 360 0.15
360 40.0 360 0
1600 66.7 600 0.15
200 70.0 1000 2
1260 91.0 1510 0.40
120 93.0 1510 0
540 102.0 25 2.75
Fast firing schedule
Fast firing schedule for firing parts printed in Alumina 4N Resin
0 0 25
2000 33.33 500 0.25
475 41.25 25 1
0 41.25 25
300 46.25 1000 3.25
1260 67.25 1510 0.40
120 69.25 1510 0
540 78.25 25 2.75
Additional resources
