Form Cure L V2 time and temperature settings
The Form Cure L V2 helps 3D printed parts achieve their highest possible strength and stability. Optimal post-curing settings depend on equipment and the geometry of the part. Select the material type and version below to see the recommended Form Cure L time and temperature settings. To post-cure previous resin formulations with the Form Cure L, use the recommended time and temperature for the closest resin version.
Tip:
  • Over-curing is acceptable, unless otherwise stated. Increase the post-curing time for thick, bulky parts because they are slower to heat to the proper temperature.
  • For parts printed in a resin for a biocompatible application, follow the post-curing steps in the relevant instructions for use or application guide. For Formlabs Fast Cure settings, see the support article Fast Cure time settings.
Form Cure L V2 settings
Downloadable PDF
Formlabs updates post-curing settings periodically with new and improved materials. Download the latest PDF version (English only), and check for updated post-curing settings when using a new resin or revised formulation.
