Introduction to Alumina 4N Resin
Alumina 4N Resin is a high-density and high-purity technical ceramic with exceptional performance in extreme environments: thermally resistant, hard, abrasion resistant, mechanically strong, and chemically inert. Conventionally it is manufactured by pressing or ceramic injection molding, both of which require expensive tooling in order to produce parts.
A collection of parts printed in Alumina 4N Resin
Alumina is used in situations where metals and polymers would fail, be it high temperature, extreme abrasion, or zero deflection. Once fired, the material becomes a true high density ceramic with comparable properties to traditionally manufactured alumina.
Alumina 4N Resin requires firing before it is ready for use, as well as a specific wash solution.
Read the articles and documents linked below to learn how to handle, print, and store Formlabs Alumina 4N Resin.
Note:
To learn more about the performance or specific material properties of Alumina 4N Resin, refer to the Safety Data Sheet (SDS) and Technical Data Sheet (TDS). Always consult the SDS as the primary source of information to understand safety and handling of Formlabs materials.
Alumina 4N Resin resources
