Replacing the Fuse 1 generation SOM
The Fuse 1 generation system on a module (SOM) plugs in to the motherboard and runs firmware on the printer. A malfunctioning SOM may cause the printer to freeze during initialization or fail to turn on.
Use this guide to replace the SOM on a Fuse 1 generation printer.
Required supplies:
  • Replacement Fuse 1 generation SOM
Third-party:
  • 1.5 mm hex driver (flat-end)
  • 3 mm hex driver (must have a 90º head)
  • ESD-safe spudger (recommended) or ESD-safe tweezers
  • Antistatic wrist band
  • Safety glasses
  • Nonreactive nitrile gloves
Estimated time: 45–60 minutes
Danger:
Warning:
Preparing the workspace
Overview: Prepare the printer and a dust-free workspace for replacing the SOM.
Step 1: Prepare the workspace
Step 2: Transfer powder credit
Before continuing with this procedure, transfer any powder credit on the printer to a powder card. Powder credits do not automatically transfer to the new SOM.
Step 3: Unplug the printer
Danger:
Removing the display assembly
Overview: Remove the display assembly to access the motherboard and SOM.
Step 1: Remove the display assembly
Follow the instructions for your printer type to uninstall the display assembly. Do not separate the motherboard from the display, but remember to unplug the Wi-Fi antenna cable(s) from the SOM.
Removing the original SOM
Overview: Uninstall the original SOM from the motherboard.
Step 1: Remove the SOM retention screws
Using a 1.5 mm hex driver, loosen and remove the two 5 mm M2 socket head screws securing the SOM to the motherboard. Set the screws aside.
Remove the SOM
Step 2: Locate the SOM retention tabs
Remove the SOM
Remove the SOM
Locate the two retention tabs (one on each side) securing the SOM to the motherboard.
Step 3: Open the retention tabs
Use an ESD-safe spudger or a pair of ESD-safe tweezers to disengage the retention tabs by flexing them outwards slightly. The end of the SOM opposite the socket may lift up slightly.
Remove the SOM
Step 4: Remove the SOM
Gently grip the SOM by the heat sink, pivot it upwards at approximately a 30º angle, then pull it straight away from the motherboard.
Remove the SOM
Installing the replacement SOM
Overview: Insert the replacement SOM into its slot on the motherboard and secure it in place.
Step 1: Insert the SOM into its socket
Install the replacement SOM
Pick up the replacement SOM by the heatsink, then insert it into the socket on the motherboard at approximately a 30º angle. Gently push the SOM into the socket so that none of the gold pins on the SOM are visible.
Step 2: Secure the SOM with the retention tabs
Push the SOM down onto the motherboard until the retention tabs snap into place.
Step 3: Fully secure the SOM
Thread one 5.0 mm M2 screw into both of the two screw holes in the SOM. Using a 1.5 mm hex driver, tighten until finger-tight.
Reinstalling the display assembly
Overview: After replacing the SOM, reinstall the display assembly.
Step 1: Reinstall the display assembly
Follow the instructions for your printer type to reinstall the display assembly. Remember to reattach the Wi-Fi antenna cable(s) to the SOM
Finalizing the repair
Overview: After installing the replacement SOM, power on the printer and perform final checks.
Step 1: Power on the printer
Step 2: Test the repair
Transfer your powder credit back onto the printer and start a print. Monitor the printer to ensure that the print proceeds normally. Contact Formlabs Support or your certified service provider to share the results of the procedure.
