Replacing the Fuse 1 generation doser gasket
Over time, the gasket that sits between the doser and the hopper trough may degrade. It may also become damaged during other repair procedures. If the doser gasket is degraded or damaged, powder may leak from the junction between the doser and hopper trough or print enclosure.
Use this guide to replace the doser gasket on a Fuse 1 generation printer.
Required supplies:
Third-party:
Estimated time: 45–60 minutes, plus time to empty the powder hopper and print the hopper vacuum attachment, if needed
Preparing the workspace
Overview: Prepare the printer and a dust-free workspace for replacing the doser gasket.
Warning:
Do not perform this procedure if the build chamber was used for printing less than six hours prior. Failure to do so may result in serious burns. Allow the build chamber and print enclosure to fully cool to room temperature before touching or inspecting any printer components.
Step 1: Print the hopper vacuum attachment
If you have access to another 3D printer or your Fuse 1 generation printer can complete a print before servicing, print and post-process the hopper vacuum attachment. The STL file is available here.
Step 2: Prepare the workspace
Step 3: Empty the hopper
Insert an empty build chamber. Tap Settings > Calibration > Empty Hopper on the printer’s touchscreen. Follow the on-screen prompt on the Empty Hopper screen to transfer the powder from the hopper to the build chamber. This process may take up to an hour.
Step 4: Clean the hopper and powder troughs
Follow the instructions for cleaning the hopper and cleaning the powder troughs from the support article Cleaning all powder out of a Fuse 1 generation printer. You do not need to clean the other components of the printer to replace the doser assembly.
Step 5: Unplug the printer
Danger:
Removing the doser gasket
Overview: Remove the doser from your Fuse 1 generation printer, then remove the gasket from its inner face.
Step 1: Remove the doser
Uninstall the doser from your printer. Follow the steps for your specific printer type:
Step 2: Remove the doser gasket
Peel the gasket off of the inner face of the doser. Set the gasket aside for disposal.
Step 3: Wipe the doser
Use a clean paper towel to wipe away any powder that may have accumulated underneath the gasket. Ensure the surface is clean and free of debris.
Fuse 1 generation doser gasket location
Installing the replacement doser gasket
Overview: Install the replacement doser gasket on the inner face of the doser.
Step 1: Inspect the replacement doser gasket
Inspect the replacement gasket for any contamination or debris. Use a clean paper towel to wipe it clean.
Step 2: Place the replacement doser gasket on the doser
One side of the replacement gasket has adhesive pre-applied. Peel any protective layers off of the gasket and adhere it to the inner face of the doser. Make sure that the gasket does not extend into the hopper opening and that the round cutouts in the gasket sit flush against the locating pins on the doser.
Step 3: Reinstall the doser
Reinstall the doser on your printer. Follow the steps for your specific printer type:
Installing the doser gasket
Finalizing the repair
Overview: After replacing the doser gasket, perform final checks.
Step 1: Power on the printer
Step 2: Test the gasket
Refill the hopper. Check that no powder leaks are visible. Insert the build chamber into the printer and start a print. Again, check that no powder leaks during the print and that the doser operates normally. Contact Formlabs Support or your certified service provider to share the results of the procedure.
