Troubleshooting the Form Cure V2
If the Form Cure V2 encounters any abnormalities, the screen displays error messages and displays more details about the error. Follow troubleshooting steps to resolve common error codes on the Form Cure. If you encounter an error code not found in this article, refer to the general troubleshooting steps below.
General troubleshooting steps
The following steps are recommended for most issues seen on the Form Cure:
- Common steps for bugs, software issues, and electrical issues:
- Ensure that your unit’s firmware is up to date.
- Power cycle the unit using the switch on the rear of the machine. Leave the unit powered off for at least 30 seconds before powering back on.
- If an issue persists and the unit’s firmware is already up to date, manually reinstall the latest firmware package.
- If an issue began immediately after updating the unit’s firmware, roll back the firmware package to the previous version.
- Best practices for opening a support case with Formlabs Support:
- Provide photos of the error code and any other symptoms you are seeing, including videos of the following:
- Entire unit
- The display
- All three LED modules
- Note the context of the issue (e.g., did the issue occur immediately after installation, after a software update, etc.).
- Note the frequency of this issue and whether it is persistent or intermittent.
- Note all troubleshooting steps already attempted.
Error 1, Error 2, and Error 3
Error 1 , Error 2, and Error 3 indicate that an unexpected error occurred. This may be caused by a one-off firmware error. To resolve this error, follow the general troubleshooting steps.
If the issue persists, contact Formlabs Support or your authorized reseller.
Error 100, Error 101, and Error 102
Error 100, Error 101, and Error 102 indicate a software malfunction. To resolve this error, follow the general troubleshooting steps.
Error 200 and Error 201
Error 200 and Error 201 indicate a temperature sensor error. To resolve this error, follow the general troubleshooting steps.
Error 202
Error 202 indicates that a LED temperature sensor in the curing chamber reported excess temperatures and has subsequently shut down to prevent permanent damage or premature failure.
To resolve this issue:
- Reseat the LED modules cables following the steps in the support article Replacing the Form Cure V2 LED modules.
- Ensure the cooling fan is working.
- Inspect the air intakes, fan, and LED heatsinks for excessive dust buildup. Clean if necessary.
Error 203
Error 203 indicates that a temperature sensor in the curing chamber reported excess temperatures and has subsequently shut down to prevent permanent damage or premature failure.
- Unplug the unit. Wait for the unit to cool completely before plugging back in.
Error 204 and Error 205
Error 204 and Error 205 indicate that a temperature sensor in the curing chamber reported temperatures below the minimum setpoint. If any of the heaters fail to reach their setpoints during the preprint process or cannot maintain their setpoints during a post-curing cycle, the cycle is aborted.
- Replace the heaters following the troubleshooting steps in the support article Replacing the Form Cure V2 heaters.
Form Cure fails to heat properly
If the Form Cure takes too long to reach temperature or fails to heat properly, there may be an issue with the fuse or the heaters.
- Check for a blown fuse by following the troubleshooting steps in the support article Replacing the Form Cure V2 fuse. If the fuse appears damaged, replace it.
- Ensure all heaters are properly plugged in by following the troubleshooting steps in the support article Replacing the Form Cure V2 heaters to Step 3: Connect the heater cables.
- Replace the heaters by following the troubleshooting steps in the support article Replacing the Form Cure V2 heaters.
LED modules do not light up
If one or more LED modules do not light up, there may be an issue with the LED module cables, or the LED modules may need to be replaced.
- Reseat the LED module cables following the steps in the support article Replacing the Form Cure V2 LED modules.
- Replace the LED modules following the steps in the support article Replacing the Form Cure V2 LED modules.
Display unresponsive or glitchy
Display malfunctions can include any of the following symptoms:
- Unresponsive display
- Glitches
- Inverted display
- Inverted colors
Turntable not spinning
If the Form Cure’s turntable is not spinning during post-curing cycles, there could be an issue with the turntable motor.
- Inspect the curing chamber. Ensure there is no debris blocking the turntable.
- Do not overload the turntable.
- Replace the turntable motor by following the steps in the support article Replacing the Form Cure V2 turntable motor.
Form Cure turns off randomly
If the Form Cure turns off on its own, there may be an issue with the supplied power, the fuse, or the firmware.
- Plug the Form Cure into another outlet or power source.
- Try using another power cable, if one is available.
- Ensure that your unit’s firmware is up to date. If the unit’s firmware is already up to date, manually reinstall the latest firmware package.
Tacky or weak post-cured parts
If parts are tacky or weaker than expected after post-curing, check your solvent and Form Cure:
- Make sure your printed parts are fully dry before post-curing.
- For solvents that evaporate readily, such as IPA, make sure to allow adequate time and ventilation for all solvent to evaporate.
- For solvents that do not evaporate readily, such as TPM or Formlabs Resin Washing Solution, remember to wash the solvent off with water, as recommended.
- Consider using compressed air to aid in drying your parts.
- Check your wash solvent’s resin saturation level and replace the solvent if needed.
- The Form Cure V2 uses three banks of LEDs to post-cure printed parts. If parts are still tacky or weak despite being fully clean and dry before post-curing, these LEDs may need to be replaced.
- Turn and press the knob to Settings > System > Statistics. The Statistics screen appears, displaying the unit’s number of Total Cycles, Heat Cycles, and hours of LED Usage. The LED modules are rated to 660 hours of use, but any degradation in performance after that point is usually gradual. You can continue to use the LED modules well past this rating, until you see adverse effects on curing performance. Production users who want to avoid downtime may want to replace the LED modules more proactively.
- Form Cure V2 LED modules are available for purchase on the Formlabs Store. Follow the instructions in the guide for replacing the Form Cure V2 LED modules to replace the component.
