Avviso:
Leggi sempre la scheda dati di sicurezza fornita dal produttore del solvente come principale fonte di informazioni relativamente alla conservazione e alla manipolazione.
Avviso:
The Form Studio Wash+Cure removes uncured resin from the surface of printed parts by simultaneously soaking and moving them in a solvent. The machine can be used with Formlabs Resin Washing Solution, isopropyl alcohol (IPA), or tripropylene glycol monomethyl ether (TPM).
After your parts are washed and dried, swap the wash bucket for the turntable and switch the machine to cure mode. Place the printed parts on the turntable and post-cure them so the resin achieves its optimal mechanical properties.
The table below indicates the recommended times to wash and post-cure parts printed in Formlabs resins using the Form Studio Wash+Cure. Formlabs updates wash settings periodically with new and improved materials. Check for updated wash settings when using a new resin or revised formulation.
Note:
When using TPM, wash your printed parts as you would with IPA. Use longer wash times if necessary—some resins will not absorb TPM or swell as much with exposure to the solvent. Refer to the support article Washing prints with TPM for more information about the TPM wash process and the effect of TPM on resins.
| Resin | Wash time | Post-cure time |
| Alpha Black Resin V1 | 5 minutes (or until clean) | 5 minutes |
| Alpha Clear Resin V1 | 5 minutes (or until clean) | 5 minutes |
| Alpha Fast Resin V1 | 5 minutes (or until clean) | 5 minutes |
| Alpha Grey Resin V1 | 5 minutes (or until clean) | 5 minutes |
| Alpha Model Resin V1 | 5 minutes (or until clean) | 5 minutes |
| Alpha White Resin V1 | 5 minutes (or until clean) | 5 minutes |
| Flexible 80A Resin V2 |
5 minutes + 5 minutes (or until clean) Wash parts printed in Flexible 80A Resin V2 in two cycles, preferably using fresh solvent for the second wash. |
Step 1 (optional): Place dry parts in a glass beaker (or other UV-transparent container) and completely submerge the parts in room temperature water. Cure for 5 minutes. Step 2: Remove parts from water. Cure for 30 minutes. |
| Tough 1500 Resin V2 (Form Studio 1) |
10 minutes (or until clean)
25 minutes |
| True Cast Resin V1 |
5 minutes Dry with compressed air, rinse with fresh solvent, then dry with compressed again. |
3 minutes |
Modifica del tempo di lavaggio consigliato
Potrebbe essere necessario aumentare il tempo di polimerizzazione consigliato nei seguenti casi:
Consiglio:
Segui queste buone pratiche per il lavaggio delle stampe per ottenere parti pulite.
Riciclaggio o smaltimento del solvente usato
Alcol isopropilico (IPA), Formlabs Resin Washing Solution e Etere monometilico di tripropilenglicole (TPM).
Avviso:
Non versare la resina liquida o parzialmente polimerizzata negli scarichi, e non smaltirla insieme ai rifiuti domestici. Non versare o smaltire solvente contenente resina disciolta negli scarichi o con i rifiuti domestici. I metodi corretti e sicuri per lo smaltimento del solvente usato variano in base alle normative locali.
