Caution:
Sintering nylon powder produces laurolactam; a white powder that accumulates within the print enclosure, filter mediums, and exhaust. Proper ventilation is required whenever the printer, Fuse Sift, or Fuse Blast is operating.
Before receiving your printer and powder recovery station, prepare a space to install and operate your Fuse 1 generation printer, Fuse Sift, and Fuse Blast and to house the necessary accessories and consumables.
Read and understand the instructions manuals and their safety instructions before using the Fuse 1 generation printer or Fuse Sift.
If your product has any visible shipping damage upon delivery, add a note to the shipping receipt or bill of lading. Contact Formlabs Support or your certified service provider and provide photos of the damage, both to the unopened package and its contents.
Requisitos del espacio de trabajo
Footprints
The Fuse 1, Fuse 1+ 30W, Fuse Sift, Fuse Blast, printer’s stand, build chamber, vacuum, and powder cartridge are free standing components.
Reserve the following minimum dimensions for the most convenient access:
Environs
Consider the following additional requirements:
Caution:
Requisitos de alimentación
Fuse 1 generation printers and the Fuse Sift each require a dedicated AC circuit, providing at least 7.5 A at 230 VAC (EU) or 15 A at 120 VAC (US), as well as reliable grounding. These circuits must be separate from other devices, including fans, vacuums, power tools, space heaters, or any large appliances or power tools. Power surges may disrupt prints and/or permanently damage sensitive components, jeopardizing the reliability of the product. Formlabs suggests the use of line conditioners or UPS in regions with voltage fluctuations.
The Fuse Sift requires an AC circuit capable of powering both the Fuse Sift and the third-party vacuum. Consult the manuals for both units and follow all relevant electrical codes. When connecting a vacuum to the Fuse Sift, use a vacuum that draws 14 A or less to prevent damage to the unit.
The Fuse Blast requires an AC circuit providing at least 3 A at 230 VAC (EU) or 6 A at 120 VAC (US). The circuit does not have to be dedicated to the unit, but it cannot share a circuit with a Fuse 1 generation printer or Fuse Sift.
Requisitos de la red
Two RJ-45 Ethernet LAN ports or a WPA2 Wi-Fi network that provides send and receive access to ports UDP 9993 and HTTPS 443, as well as api.formlabs.com. For more information, refer to the support article Connecting a Fuse 1 generation printer, Fuse Sift, or Fuse Blast via USB, Ethernet, or Wi-Fi.
Suministros adicionales
Aside from the contents of the Fuse 1 and Fuse Sift package, you need additional supplies to post-process your printed parts and to clean and maintain the printer and powder recovery station.
Prepare your workspace by purchasing them in advance:
You can adapt your own compliant vacuum to connect to the Fuse Sift, provided its power draw does not exceed what the Fuse Sift can deliver.
For your reference:
One end of the cable needs to terminate in a IEC 320 C20 plug to connect to the Fuse Sift. The other should terminate in whatever socket is required to connect to your vacuum.
Tip:
More information on supplies, such as personal protective equipment (PPE):
Siguientes pasos
