Print Settings guide
This article outlines the print settings available for Formlabs printers to help you choose a material that suits your application’s needs.
Tip:
When printing for the first time, use Formlabs Default Print Settings, as they are designed and tested by Formlabs directly.
For more information about using advanced print settings, see the article Introduction to the PreForm Print Settings Editor.
For more information about which SLS print setting is best for different feature types and print defects, see the article Choosing the right print setting (SLS).
Understanding print settings
A print setting is a collection of parameters that controls the behavior of a Formlabs printer. Each setting is dependent on printer generation, material, layer height, and PreForm version. Print settings can directly impact every aspect of your print’s quality, accuracy, speed, and part properties. Print settings can be found in PreForm’s Job Setup view.
Key terms
Print Setting identifier: A name given to different print settings options available in a given version of PreForm. What specific parameters are tied to each of these identifiers is unique to a given PreForm version, and they do not carry over from one PreForm version to another.
Print Setting descriptor: A description of a print setting’s intended use.
Version number: Each print setting has a version number, displayed next to its name in the format Major.Minor. A new major revision denotes an improvement in reliability, supports, or print time. A new minor revision denotes a smaller change to the print settings between major releases.
Formlabs Print Setting: A print setting treated by Formlabs as indicated by a Formlabs icon. To create a custom print setting, you can use these settings as a template to make adjustments.
Custom Print Setting: A setting that is created by a user in the Print Setting Editor based on the original parameters of a Formlabs Print Setting.
Parameter: A numerical factor that characterizes a member of a print setting.
  1. Print setting identifier
  2. Print setting descriptor
  3. Preset print setting icon
  4. Major version number
  5. Minor version number
alttext
  1. Custom print setting identifier
    1. Set when creating or editing a custom print setting with the Print Settings Editor
  2. Custom print setting descriptor
  3. Custom print setting version number
    1. Increments when the custom print setting is modified and saved. The major and minor version numbers for a custom print setting are the same as those for the preset print setting it was originally based on.
alttext
Additional resources
