Tuning the bed temperature of your Fuse 1+ 30W printer for improved part yield with Nylon 12 Tough Powder
Nylon 12 Tough Powder requires aging and bed temperature tuning before first use. After aging the powder, but prior to printing as normal, fine-tune your Fuse 1+ 30W printer to set up your prints for success. Fine-tuning the bed temperature prior to printing your first build results in fewer surface defects on your parts caused by variable printer temperatures. This process is run as a diagnostic print, uploaded through PreForm to the printer. The print contains several parts that need to be cleaned and inspected to determine the necessary temperature offset for your printer. Run this process using the previously-aged powder, refreshed with 20% fresh powder.
Note:
Every Fuse 1+ 30W printer should be fine-tuned when printing with Nylon 12 Tough Powder for the first time. Printers next to each other may require different offsets.
alttext
Run the Bed Temperature Tuning Print
  1. If you have previously used the printer with an applied offset, reset the printer’s offset to 0 prior to beginning the fine-tuning process. This can be done by following the directions to Set the bed temperature offset, and setting the printer offset to 0.
  2. Update PreForm to its latest version.
  3. Download the Nylon 12 Tough Bed Temperature Tuning Print.
  4. Open PreForm and select Job Settings.
  5. In the Job Setup window, make sure the correct printer is selected, then select Upload Diagnostic Print.
alttext
  1. Select the file from your computer. Once the file has successfully uploaded, start the print from your printer.
  2. To run the print, 3 kg of powder is required. Use the Fuse Sift to mix 80% aged powder with 20% fresh powder (a 20% refresh rate). To load the printer’s hopper with 3 kg of powder, fill the hopper to the 7 L mark.
  3. Allow the print to fully cool per Formlabs recommendations.
Clean the parts
Once the print completes, parts can be extracted from the build chamber by using the Fuse Sift or the Fuse Depowdering Kit. Excess powder can be sifted with fresh powder and re-used.
Parts should be fully cleaned of powder prior to inspection either by the Fuse Blast or other media blasting solutions. Extract the five plaques with cones. The additional flat plaques in the build are used to create equal cooling and separation between each cone plaque and can be discarded.
A cleaned Nylon 12 Tough Powder tuning print
Each plaque is listed with the temperature offset it was printed with (-2 ºC, -1 ºC, 0 ºC, +1 ºC, +2 ºC). Line the plaques up from -2 ºC to +2 ºC to prepare for inspection.
Inspect the plaques
Note:
If the test print fails and not all plaques are completed, complete the inspection using the plaques that printed successfully. The correct offset will be included in the parts that printed successfully.
To determine the appropriate temperature offset for your printer, look for the plaque at the coldest temperature setting that has the fewest instances or no instances of orange peel.
Rotate the plaques to inspect the cones from all angles. Orange peel appears as a slightly layered surface on the cones.
An example of orange peel on a part printed with Nylon 12 Tough Powder
