Diagnosing a print failure (SLS)
During a successful SLS print, the laser sinters powder to build parts layer by layer. After the parts cool, separate the printed parts from the unsintered powder. Post-process the printed parts and reserve the unsintered powder for reuse or disposal.
Normally, an SLS 3D printed part has a slightly grainy surface. If the temperature inside the build chamber is too hot, or not hot enough, the resulting temperature difference causes defects on the part’s surface. Obstructions in the laser path can also cause print defects.
Best practices
Fuse 1 generation
To reduce the likelihood of print failures, follow Formlabs instructions and perform routinely scheduled maintenance on your Fuse 1 generation printer:
Fuse X1
To reduce the likelihood of print failures, follow Formlabs instructions and perform routinely scheduled maintenance on your Fuse X1 printer:
  • Use the recommended refresh rate for your material
  • Adjust the bed temperature for optimal part quality
  • Clean the build sheet and troughs between prints
  • Clean the recoater roller between prints
  • Clean the lower laser window
  • Clean the IR sensor and IR sensor housing
  • Wait for the internal temperature to drop to 30 °C (86 °F) before removing or handling the build unit
Print defect overview
If you experience print defects with a Formlabs SLS printer, consult the list below and visit the relevant support article to troubleshoot and resolve them.
Dimpling and pitting
Symptoms:
  • Top surfaces of parts are sunken in (dimpling) or completely collapsed (pitting)
Troubleshooting steps:
Dimpling and pitting (SLS)
SLS parts with pitting
Layer shifting
Symptoms:
  • At a given layer height, there is a horizontal distortion which appears as a line, bulge, or step
  • Shift may be found at multiple layer heights
  • Shift is present throughout the entire part and not just the surface
Layer shifting (SLS)
SLS parts with layer shifting
Horizontal bands
Symptoms:
  • Periodic ripples along vertically-oriented surfaces
Horizontal banding (SLS)
SLS parts with horizontal banding
Poor finish or orange peel texture on vertical surfaces
Symptoms:
  • Ridges or waves across vertical surfaces
  • Surfaces closer to the edges of the build volume may have this while other surfaces do not
Poor finish on vertical surfaces (SLS)
SLS parts with poor surface finish
Warping
Symptoms:
  • The shape of the part is deformed
  • Parts that should be straight are curved or twisted
Warping (SLS)
SLS warped parts
Fragile parts
Symptoms:
  • Printed parts crumble easily and their texture is more grainy than usual
Fragile parts (SLS)
SLS fragile parts
Bumps along Z-axis
Symptoms:
  • Distortion or extra material which extends along the printer Z-axis
Bumps along Z-axis (SLS)
SLS parts with pumps along the Z-axis
Blurred or missing features
Symptoms:
  • Fine features in the print plane are rounded off or missing
  • Areas of the printed part are missing along the printer's Z axis
Blurred or missing features (SLS)
Printed parts with blurred or missing features
Delamination
Symptoms:
  • Layers are not fully adhered
  • Layer separation may be localized or go through the entire part
Delamination (SLS)
SLS delamination
SLS delamination
Powder contamination
Symptoms:
  • Isolated blown out area on the side of a part
  • Foreign debris such as hair embedded in the part
Powder contamination (SLS)
SLS part showing evidence of powder contamination
Recoater artifacts
Symptoms:
  • Periodic gouges, ridges, or protrusions on the top surfaces of parts oriented along the direction of motion of the recoater roller
Remove and clean the printer's recoater roller.
SLS part showing evidence of recoater roller artifacts
Hard caking
Symptoms:
  • Printed parts are difficult to separate from powder cake
  • Surface Armor is difficult to clean from parts
Hard caking (SLS)
SLS hard cake
