Downloading printer history (SLS)
Viewing activity logs can be useful when maintaining or troubleshooting your printer. Download print history, error message, and maintenance logs from your Formlabs printer via PreForm to save or analyze.
Note:
Printer history is available to download from Fuse 1 generation printers running firmware 1.19.0 or later through PreForm 3.41 or later. Print videos were added to the printer history download in firmware version 1.22.0.
Connect to a Formlabs SLS printer via PreForm to download the printer history package. To download your printer history:
  1. Open the latest version of PreForm.
  2. Connect the printer to the computer via Wi-Fi, USB or wire the printer to an Ethernet network.
  3. Click Edit Job Setup. The Job Setup window opens.
  4. Select the printer whose logs you want to download.
  5. Click Download History (CSV) in the Job Setup pane. An archive containing three CSV files, multiple videos, and a folder of images is downloaded to your computer.
    1. PrintHistory.csv: Lists all print jobs started and their resolution
    2. ErrorHistory.csv: Lists all errors shown on the Error History screen on the printer along with relevant printer data
    3. MaintenanceHistory.csv: Lists all maintenance tasks that have been performed
    4. PrinterWatcherFrames: A selection of print photos taken by the integrated camera from prints that failed due to a PrinterWatcher error
    5. Prints listed in PrintHistory.csv that started and had layers printed have two videos in the archive. One video is made from photos taken before each layer was lased, while the other video is made from photos taken after lasing but before recoating powder for the next layer.
Downloading SLS printer history in PreForm
Viewing printer history
The printer history package contains three CSV files:
  • PrintHistory.csv: Lists all print jobs started and their resolution
  • ErrorHistory.csv: Lists all errors shown on the Error History screen on the printer along with relevant printer data
  • MaintenanceHistory.csv: Lists all maintenance tasks that have been performed
Print history
The PrintHistory.csv file contains a list of print jobs that have been started on the printer, along with details about the prints and their resolution.
The following fields are available in this log file:
NameDescription
Serial NamePrinter serial name
Machine TypePrinter type (e.g., Fuse 1 or Fuse 1+ 30W)
StartedTime that the print job was started (UTC)
EndedTime that the print job ended (UTC)
Job NamePrint job name (defined in PreForm)
UserUser that uploaded the print job (if logged in). Field left blank if the uploader was not logged in.
Job GuidPrint job unique identifier
Job MaterialMaterial type for the print job
Total Layer CountTotal number of layers in the print job
Print GuidPrint unique identifier
Last Successful LayerLast layer completed before the print ended (-1 means the print job was aborted during preprint)
StatusFinal status of print job: Printing, Error, Aborted, or Finished
Build Chamber SerialBuild chamber serial number
Firmware VersionFirmware version installed on the printer when the print job was run
Error history
The ErrorHistory.csv file contains a list of error messages that have occurred on the printer. It offers a more detailed and complete view of sensor readings at the time of each error message than the onboard Error History screen.
All values were valid at the time when the error occurred. The following fields are available in this log file:
Name Description Units
Time of OccurrenceTime at which the recorded error occurred (UTC)
ErrorError code
User NameUser that uploaded the print job (if logged in). Field left blank if the uploader was not logged in.
LayerLayer number at which the error occurred
Printer MaterialMaterial type assigned to the printer
Cylinder MaterialMaterial type assigned to the build chamber
Event UUIDError event unique identifier
Print UUIDPrint unique identifier
Job UUIDPrint job unique identifier
Air heater temperatureTemperature measured by the sensor in front of the air heater˚C
Bed temperatureTemperature measured by the IR sensor˚C
Buffer trough temperatureTemperature measured by the sensor below the buffer trough˚C
Cylinder wall top temperatureTemperature measured by the sensor by the upper wall of the build chamber˚C
Cylinder wall temperatureTemperature measured by the sensor by the lower wall of the build chamber˚C
Hopper trough temperatureTemperature measured by the sensor below the hopper trough˚C
Laser temperatureTemperature measured by the sensor in the laser assembly˚C
Nitro temperatureTemperature measured by the sensor on the nitrogen board (Fuse 1+ 30W)˚C
Piston top temperatureTemperature measured by the sensor below the build chamber piston top˚C
Chamber in fan speedMeasured speed of the intake fanRPM
Chamber out fan speedFuse 1: Measured speed of the exhaust fan
Fuse 1+ 30W: Measured speed of the recirculation fan
RPM
Nitro pressurePressure measured by the transducer at the inlet of the nitrogen system (Fuse 1+ 30W)Pa
Chamber pressureFuse 1: Pressure measured through a tap connected to the print chamber
Fuse 1+ 30W: Pressure measured through a tap connected to the recirculation fan plenum
Pa
Intake pressureFuse 1: Pressure measured through a tap connected to the intake fan plenum
Fuse 1+ 30W: Pressure measured through a tap connected to the nitrogen plenum
Pa
Door handle stateWhether the door latch registers as open or closedOn/Off
Air valve stateWhether the air ball valve is open or closed (Fuse 1+ 30W)On/Off
Nitro valve stateWhether the nitrogen ball valve is open or closed (Fuse 1+ 30W)On/Off
Filter door stateWhether the filter door switch registers as open or closedOn/Off
Interlock 1 stateWhether one of the door magnet sensors registers as open or closedOn/Off
Interlock 2 stateWhether one of the door magnet sensors registers as open or closedOn/Off
TCO monitor stateWhether the thermal cutoff fuse is open or closedOn/Off
Maintenance history
The MaintenanceHistory.csv file contains a list of maintenance tasks performed on the printer, as logged on the Maintenance screen on the printer.
NameDescription
Total Print Hours SinceAmount of print time in hours since firmware version 1.18.0 was installed (when print time tracking was introduced)
Time of MaintenanceTime when the listed maintenance task was performed (UTC)
Time Since Last MaintenanceAmount of print time since the listed maintenance task was performed. Print time is defined as in PreForm, starting with preprint and ending when the build chamber cools to 100 ℃.
Type of MaintenanceMaintenance task performed
Viewing print photos
The folder PrinterWatcherFrames contains subfolders for prints that failed due to PrinterWatcher errors, each with 10 print photos taken by the onboard camera. These are the same photos shown on the printer touchscreen after these errors, and can be particularly helpful when diagnosing a print failure or troubleshooting an error message related to the PrinterWatcher system. Several sample images are given below.
Example PrinterWatcher image
Viewing print videos
The downloaded archive also contains videos for prints listed in PrintHistory.csv that started and had layers printed. The video names correspond to the Print UUID in the ErrorHistory.csv file and the Print Guid in the PrintHistory.csv file. Like the print images, these videos can be helpful when diagnosing a print failure or troubleshooting an error message related to the PrinterWatcher system.
Troubleshooting errors
Occasionally, error messages (e.g., Error: Bad State) may appear when downloading printer history logs. If this happens:
  1. Ensure the printer is running firmware version 1.22.1 or newer. Reflash the firmware even if the printer is already on the latest version.
  2. Delete old or unnecessary print jobs stored on the printer to free up memory.
  3. Perform a factory reset on the printer by tapping Settings > System > Factory Reset. Start a new print job. Attempt to download the logs again.
