BioMed White Resin is a medical-grade material designed for a wide range of end-use applications where performance, aesthetics and biocompatibility are critical. BioMed White Resin is USP Class VI certified, and printed parts are validated for long-term contact with skin and short-term mucosal membrane contact. BioMed White Resin is also certified for short-term contact with tissue, bone, and dentin.
BioMed White resin can be sterilized by autoclave, E-beam, gamma, and ethylene oxide.
Note:
To learn more about the performance or specific material properties of BioMed White Resin, please refer to the Safety Data Sheet (SDS) and Technical Data Sheet (TDS). Always consult the SDS as the primary source of information to understand safety and handling of Formlabs materials.
Recommended for:
| BioMed Black Resin | BioMed White Resin | BioMed Clear Resin | BioMed Amber Resin | |
| Can be sterilized | ✔ | ✔ | ✔ | ✔ |
| Transparent | ✔ | ✔ | ||
| Can be polished | ✔ | ✔ | ✔ | ✔ |
| Compatible with Form 2 | ✔ | ✔ | ✔ | ✔ |
| Compatible with Form 3B/3B+//3BL | ✔ | ✔ | ✔ | ✔ |
| Certifications | USP Class VI ISO 10993-5, -10,-23 | USP Class VI ISO 10993-5, -10,-23 USP <151> Pyrogen + ISO 10993-11 Acute systemic Toxicity Testing | USP Class VI ISO 10993-5, -10,-23 ISO 18562-1,-2,-3,-4 | ISO 10993-5, -10,-23 ISO 13485 |
| Layer thickness | 50 microns 100 microns | 50 microns 100 microns | 50 microns 100 microns | 50 microns 100 microns |
| Ultimate tensile strength (MPa) | 35.7 | 45.8 | 52 | 73 |
| Tensile modulus (GPa) | 1.5 | 2.0 | 2.1 | 2.9 |
| Elongation at break (%) | 14 | 10 | 12 | 12.3 |
| Flexural modulus (GPa) | 1.7 | 2.0 | 2.3 | 2.5 |
| IZOD Impact strength (J/m) | 24.8 | 15.1 | 35 | 28 |
| Heat deflection temperature (HDT) @ 1.8 MPa | 49.4 | 52.4 | 54 | 65 |
| Heat deflection temperature (HDT) HDT @ 0.45 MPa (°C) | 68 | 67 | 67 | 78 |
To learn more about the performance properties of Formlabs resins, refer to the library of material properties data sheets.
Required resources
Made by Formlabs:
Printing
Washing
Follow the part washing recommendations in the manufacturing guide for the clearest and best possible results. Improper washing can lead to suboptimal mechanical and biocompatibility properties.
Post-curing requirements
BioMed White Resin requires post-curing to reach its optimal mechanical properties.
Follow the post-curing recommendations in the manufacturing guide for the clearest and best possible results. Improper post-curing can lead to suboptimal mechanical and biocompatibility properties.
Additional resources
