Replacing the Form 4L LevelSense board
The LevelSense board detects the amount of resin in the resin tank. The LevelSense board sits at the left side of the tower in the printer. A malfunctioning LevelSense board may prevent the printer from printing properly.
Use this guide to replace the LevelSense board on a Form 4L generation printer.
Required Supplies:
  • LevelSense board
  • 2 mm hex driver (included in the Form 4L tool caddy)
Third-party:
  • Nitrile gloves
  • Small plastic card (e.g., identification card)
Estimated time: 10–15 minutes
Preparing the workspace
Overview: Prepare the Form 4L and workspace for replacing the LevelSense board.
Remove the build platform first to avoid dripping resin onto the Light Processing Unit (LPU).
Step 3: Remove and store the resin tank and mixer
NOTICE:
Step 4: Prepare the workspace
Step 5: Clean the printer
WARNING:
Open the printer cover and clean any resin pooled on and around the LPU with non-abrasive wipes. Dampen the wipes with isopropyl alcohol if necessary to fully remove the resin.
DANGER:
Step 6: Unplug the printer
Removing the LevelSense board
Overview: After preparing the printer and workspace, remove the LevelSense board.
Step 1: Remove the LevelSense shroud
Open the printer door and locate the plastic shroud at the back left of the printer. Use a 2 mm hex driver to remove the four screws securing the plastic shroud to the printer. Set the shroud aside.
Step 2: Remove the LevelSense board mounting screws
Support the LevelSense board from below to prevent it from falling when the screws are removed. Use a 2.5 mm hex driver to remove the three screws securing the LevelSense board to the metal bracket. Set the screws aside.
Step 3: Disconnect the LevelSense board cable
Press the plastic tab on the connector to release the cable that connects to the LevelSense board. Once the plastic tab is pressed, the cable easily slides from the connector. Do not pull on the wires. Remove the LevelSense board and set it aside for disposal with electronic waste.
Installing the replacement LevelSense board
Overview: Connect and install the replacement LevelSense board.
Step 1: Connect the cable
Reconnect the cable that connects the LevelSense board. The connector makes an audible and tactile click when secured.
Step 2: Mount and secure the LevelSense board
Position the LevelSense board so that the screw holes align with the holes in the bracket. Use a 2 mm hex driver to install the three screws that secure the LevelSense board to its bracket. Tighten until snug.
Step 3: Mount and secure the LevelSense shroud
Place the LevelSense shroud on top of the LevelSense bracket. Align the four screw holes in the shroud with the corresponding holes in the bracket. Use a 2 mm hex driver to install the four screws securing the plastic shroud to the printer. Tighten until snug.
Finalizing the repair
Overview: After installing the replacement LevelSense board, power on the printer and perform final checks.
Step 1: Power on the printer
Close the printer door and connect the power cable to the printer and the power supply. Turn on the switch at the back of the printer. The printer turns on and initializes.
Step 2: Calibrate the LevelSense board
On the printer touchscreen, tap Settings > Tools > Calibration > Resin Level Sensor. The Calibrate resin level sensor screen appears. Tap Start and follow the on-screen instructions to calibrate the LevelSense board. You will need a small plastic card with no embossing, such as an identification card.
