Produktglossar (Fuse Sift)
Tipp:
Besuchen Sie die Fuse Interaktive Sift-Tour für eine 3D-Ansicht vieler Komponenten detailliert.
Arbeitsbereich und externe Komponenten
ItemDescriptionImage
HoodPrevents powder and debris from leaving the Fuse Sift’s workspace.
Control panelA touchscreen and physical control panel for interfacing with the Fuse Sift.
VacuumThe vacuum hose and power cord plug into ports on the side of the Fuse Sift, allowing the vacuum to be controlled via the Fuse Sift's touchscreen or control panel.
Vacuum hoseConnected to the external vacuum for cleaning the Fuse 1 and Fuse Sift after use.
Tool shelfStorage for break-out tools and brushes.
Parts basketStorage container for extracted parts while processing a cake.
VentA fan pulls dispersed powder into a filter, preventing plumes from leaving the workspace.
LightThe light illuminates the workspace while extracting and cleaning printed parts.
SifterThe sifter agitates and breaks up clumps of unsintered powder from previous prints before it is recaptured for reuse.
Surface grateProtective grate covering the sifter.Surface grate
Powder catchRemovable tray for catching loose powder.Powder catch
MixerThe mixer spins a filled powder cartridge to ensure a homogeneous distribution of fresh and used powder.
Konstruktionskammer
Build chamberAn interchangeable component of the Fuse 1 that contains the print bed, heaters and temperature sensors, and encapsulates the sintered parts and loose powder from a print. The accompanying plug allows the Fuse 1 and Fuse Sift to monitor the build chamber, and differentiate one build chamber from another.
Build chamber enclosureArea for housing the build chamber with prints ready to be ejected. Build chamber enclosure
Build chamber portAccess port for the cooled powder cake to enter the workspace.Build chamber port
Build chamber latchSecures the build chamber.Build chamber latch
Build chamber socketConnects the build chamber’s plug.Build chamber socket
Handhabung des Pulvers
Sifter meshThe sifter mesh filters reusable powder from unusable powder.Sifter mesh
Fresh powder hopperThe fresh powder hopper holds unused powder for dispensing into a powder cartridge.
Used powder hopperThe used powder hopper holds recaptured powder for dispensing into a powder cartridge.
Fresh powder hopper lidAccess point for filling the fresh powder hopper.Fresh powder hopper lid
Doser assemblyThe doser assembly dispenses fresh and used powder into a powder cartridge in a ratio matching the selected refresh rate.Doser assembly
Cartridge drawerHolds the powder cartridge while it is being filled with powder. Weight sensors in the cartridge drawer ensure that the cartridge is filled properly.
Hauptplatine und Elektronik
MotherboardThe main circuitry through which all systems in the machine communicate.
Power supplyThe Fuse Sift requires a 230 VAC (50 Hz), 7.5 A power supply (EU) or 120 VAC (60 Hz), 15 A power supply (US) for nominal operation.Power supply
Wi-Fi antennaThe Wi-Fi antenna enables the Fuse Sift's wireless connectivity. The antenna is connected to the machine's motherboard.Wi-Fi antenna
Ethernet and USB portsThe Fuse Sift can connect to a network via Ethernet or to a computer via USB. These ports are connected to the motherboard and can be accessed from the back of the machine.
Bedienfeld
TouchscreenInteractive touchscreen for controlling subsystems and settings of the Fuse Sift.
Physical controls
  • Bed chamber controls: physical control for raising and lowering the print bed into and out of the workspace
  • Sift button: physical control for starting and stopping the sifter
  • Vac button: physical control for turning on and off the workspace light and vent
  • Vacuum button: physical control for turning on and off the auxiliary vacuum
Pulverkartusche
ArtikelBeschreibungAbbildung
PulverkartuscheDer Behälter, in dem SLS-Pulver gemischt und vom Fuse Sift zum Trichter des Druckers transportiert wird.Powder cartridge
KartuschenflügelZwei Halterungen zum Verriegeln der Kartusche am Mischer.Cartridge wings
KartuschenventilDie primäre Öffnung zum Befüllen und Ablagern von Pulver.Cartridge valve
VentilklappeDient zum Schließen und Öffnen des Kartuschenventils.Valve knife
GriffeZum Halten und Anheben der Kartusche.Handles
Mischer
MischerdrehtellerDie Außenseite des Mischers, die sich mit der Kartusche dreht.Mixer turntable
ArretierlaschenZwei federbelastete Laschen zur Befestigung der Kartusche im Mischer.Locking tabs
KartuschenflügelkupplungenZwei Halterungen, die die Flügel der Kartusche in Position führen. Cartridge wing couplers
