Using Permanent Crown Resin
The Stainless Steel Build Platform is required for printing with Permanent Crown Resin.
Permanent Crown Resin is a tooth-colored resin for 3D printing of permanent crown restorations, inlays, onlays and veneers. Digitally created restorations enable a quick, collaborative process between dentist, technician, and patient.
Available in four VITA* Classical shades, this material can be characterized with glaze and composite stains. Permanent Crown Resin's high flexural strength and modulus enable excellent dimensional stability and strength.
Permanent Crown Resin prints at 50 microns.
Note:
To learn more about the performance or specific material properties of Permanent Crown Resin, please refer to the Safety Data Sheet (SDS) and Technical Data Sheet (TDS). Always consult the SDS as the primary source of information to understand safety and handling of Formlabs materials.
Required resources
Made by Formlabs:
Made by third parties:
  • Intraoral or desktop optical scanner
  • Dental design software
  • Low-speed dental handpiece with cutting and finishing wheels
  • Sandblaster
  • Glass bead blasting material (Perlablast® recommended)
  • Polishing or glazing instruments and materials
  • Isopropyl alcohol (IPA) ≥ 99%
Workflow overview
Read the instructions for use [en] for detailed instructions about the workflow for Permanent Crown Resin.
Scan
In order to 3D print an impression tray, use a scanner to collect anatomical data of the patient’s dentition. Either scan the patient directly with an intraoral scanner, or use a desktop optical scanner to scan a polyvinyl siloxane (PVS) impression or stone model.
Design
Use a dental CAD software package to process and design the restoration before printing. Choose software that offers open STL file export.
Feature requirements
Minimum thickness (single crowns, inlays, onlays, veneers): 1.0 mm
Print
A Stainless Steel Build Platform is required for printing with Permanent Crown Resin.
  1. Open a model.
  3. Orient to preserve fine details.
  4. Generate supports.
Orient the restoration horizontally, with the occlusal plane facing the build platform.
Finish
The Form Wash agitates the solvent bath and removes parts from the bath after a set time. Wash parts according to the support article Form Wash time settings. Pay particular attention to information that affects mechanical properties or biocompatibility requirements.
If the model is hollow or has internal channels, ensure liquid resin is flushed out thoroughly from these features using a skirt bottle filled with 99% isopropyl alcohol (IPA). Use compressed air to allow parts to fully dry before post-curing.
Post-curing requirements
Permanent Crown Resin requires post-curing to reach its optimal mechanical properties. Refer to the support article Form Cure time and temperature settings for post-curing recommendations.
Step 1: Post-cure with raft and supports still attached
Leave supports and rafts in place for the first post-cure.
Step 2: Remove supports
After post-curing, remove supports. Carefully sandblast part surfaces to remove the white coating. Check the fit and contour parts as needed using a dental handpiece.
Step 3: Post-cure with supports removed
Post-cure parts again according to the support article Form Cure time and temperature settings with the occlusal plane facing upward.
Step 4: Polish parts
Polish post-cured parts using pumice stone and polishing compound.
Additional resources
