Tip:
For OBJ files:
- Your modeling software should generate an OBJ file and an identically-named MTL file that contains material information. For PreForm to access this material information, the MTL file must have the same name and be in the same folder as the OBJ file.
- Some OBJ generators may create faulty OBJ files. Repairing these files with PreForm will remove the color information used for face texturing. To avoid this, either generate your model with a different application or select Ignore when PreForm displays a Broken Models Detected error.
