Note:
Duplicate copies the orientation and support structure of the original model.
There are multiple options for creating copies of a model in PreForm:
Creating a single copy with shared properties
To create a single model copy with Duplicate:
Note:
Creating multiple copies with shared properties
To create multiple model copies with Duplicate Count:
Creating multiple copies with shared properties in a grid layout
PreForm quickly arranges multiple copies of a model in a grid layout with Array, duplicating the support structure and orientation of the original model.
Tip:
As you work with Array, PreForm shows a preview. Click the central Home icon to return to the default view.
To create multiple model copies with Array:
Note:
Array copies the orientation and support structure of the original model.
Creating multiple copies to fill the build platform or build chamber
PreForm completely fills the build platform or build chamber with multiple copies of a model with Fill Build Platform and Fill Build Chamber, respectively.
To create multiple model copies with Fill Build Platform or Fill Build Chamber:
| Fill Build Platform (SLA) | Fill Build Chamber (SLS) |
Creating multiple copies to fill the build chamber to a specified height (SLS)
PreForm can fill the build chamber up to a specific height with multiple copies of a model with Copy & Fill Gaps.
To create multiple model copies with Copy & Fill Gaps:
