Tip:
Visit the Fuse Sift interactive tour for a 3D view of many of the components detailed below.
Tip:
Workspace and external components
| Item | Description | Image |
| Hood | Prevents powder and debris from leaving the Fuse Sift’s workspace. |
| Control panel | A touchscreen and physical control panel for interfacing with the Fuse Sift. |
| Vacuum | The vacuum hose and power cord plug into ports on the side of the Fuse Sift, allowing the vacuum to be controlled via the Fuse Sift's touchscreen or control panel. |
| Vacuum hose | Connected to the external vacuum for cleaning the Fuse 1 and Fuse Sift after use. |
| Tool shelf | Storage for break-out tools and brushes. |
| Parts basket | Storage container for extracted parts while processing a cake. |
| Vent | A fan pulls dispersed powder into a filter, preventing plumes from leaving the workspace. |
| Light | The light illuminates the workspace while extracting and cleaning printed parts. |
| Sifter | The sifter agitates and breaks up clumps of unsintered powder from previous prints before it is recaptured for reuse. |
| Surface grate | Protective grate covering the sifter. |
| Powder catch | Removable tray for catching loose powder. |
| Mixer | The mixer spins a filled powder cartridge to ensure a homogeneous distribution of fresh and used powder. |
Build chamber
| Build chamber | An interchangeable component of the Fuse 1 that contains the print bed, heaters and temperature sensors, and encapsulates the sintered parts and loose powder from a print. The accompanying plug allows the Fuse 1 and Fuse Sift to monitor the build chamber, and differentiate one build chamber from another. |
| Build chamber enclosure | Area for housing the build chamber with prints ready to be ejected. |
| Build chamber port | Access port for the cooled powder cake to enter the workspace. |
| Build chamber latch | Secures the build chamber. |
| Build chamber socket | Connects the build chamber’s plug. |
Powder handling
| Sifter mesh | The sifter mesh filters reusable powder from unusable powder. |
| Fresh powder hopper | The fresh powder hopper holds unused powder for dispensing into a powder cartridge. |
| Used powder hopper | The used powder hopper holds recaptured powder for dispensing into a powder cartridge. |
| Fresh powder hopper lid | Access point for filling the fresh powder hopper. |
| Doser assembly | The doser assembly dispenses fresh and used powder into a powder cartridge in a ratio matching the selected refresh rate. |
| Cartridge drawer | Holds the powder cartridge while it is being filled with powder. Weight sensors in the cartridge drawer ensure that the cartridge is filled properly. |
Motherboard and electronics
| Motherboard | The main circuitry through which all systems in the machine communicate. | |
| Power supply | The Fuse Sift requires a 230 VAC (50 Hz), 7.5 A power supply (EU) or 120 VAC (60 Hz), 15 A power supply (US) for nominal operation. |
| Wi-Fi antenna | The Wi-Fi antenna enables the Fuse Sift's wireless connectivity. The antenna is connected to the machine's motherboard. |
| Ethernet and USB ports | The Fuse Sift can connect to a network via Ethernet or to a computer via USB. These ports are connected to the motherboard and can be accessed from the back of the machine. |
Control panel
| Touchscreen | Interactive touchscreen for controlling subsystems and settings of the Fuse Sift. | |
| Physical controls |
Powder cartridge
| Powder cartridge | The container in which SLS powder is mixed and transported to from the Fuse Sift to the printer’s hopper. |
| Cartridge wings | Two brackets for locking the cartridge to the mixer. |
| Cartridge valve | The primary opening for filling and depositing powder. |
| Valve knife | Used to close and open the cartridge valve. |
| Handles | For holding and lifting the cartridge. |
Mixer
| Mixer turntable | The exterior face of the mixer that turns with the cartridge. |
| Locking tabs | Two spring-loaded tabs for securing the cartridge into the mixer. |
| Cartridge wing couplers | Two brackets that guide the cartridge’s wings into place. |
