- Do not add more than 7 mL of Polishing Agent when refilling the water tank. Excess Polishing Agent saturates the media and causes it to clump, which may require replacing the blasting media.
- Always rinse out the water tank with tap water before refilling. Failure to do so may lead to excess Polishing Agent in the water.
- Except when instructed by Formlabs, leave the flow rate set to the recommended 2 mL/min. Higher flow rates may lead to excess Polishing Agent saturating the media.
