Replacing the Form 4 cover damper
Form 4 generation printers have a damper attached to the Z-tower that softens the closing action of the cover. A damaged cover damper may cause the cover to be difficult to open and close or to close faster than expected.
Use this guide to remove and replace the cover damper on a Form 4 generation printer.
Required Supplies:
  • Cover damper
  • Cover damper bracket
  • Cover damper bracket screws (4x)
  • 2.5 mm hex driver (included in the Form 4 tool caddy)
Third-party:
  • Nitrile gloves
Estimated time: 10 minutes
Preparing the workspace
Overview: Prepare the printer and a dust-free workspace for replacing the cover damper.
Remove the build platform first to avoid dripping resin onto the Light Processing Unit (LPU).
Step 3: Remove and store the resin tank and mixer
NOTICE:
Step 4: Prepare the workspace
Clear a workspace around your printer. Ensure that the workspace is well-ventilated and free of dust. Prepare additional space for storing the back panel of the printer during maintenance.
Step 5: Clean the printer
WARNING:
Open the printer cover and clean any resin pooled on and around the LPU with paper towels. Dampen the paper towels with isopropyl alcohol if necessary to fully remove the resin.
DANGER:
Step 6: Unplug the printer
DANGER:
Removing the back panel
Overview: Remove the back panel to access the cover damper.
NOTICE:
Formlabs printers contain sensitive electronic components. Ground yourself before touching any electronics in the printer by using a grounding strap or touching a grounded piece of metal.
Step 1: Remove the back panel screws
Use a 2.5 mm hex driver to remove the eight screws securing the back panel to the printer. Set the screws aside.
Step 2: Remove the back panel
Remove the back panel by sliding it down and away from the back of the printer. Set the back panel aside.
Removing the cover damper
Overview: After preparing the printer and workspace, remove the cover damper.
Step 1: Open the printer cover
Open the printer cover to more easily access the cover damper.
Step 2: Locate the cover damper
The cover damper on the Form 4 generation printer is located on the right side of the Z-tower, as seen when facing the back of the printer. It is a small piston secured behind a rectangular bracket.
Step 3: Remove the cover damper
The cover damper sits in a bracket, which is secured to the Z-tower with four screws. Use a 2.5 mm hex driver to loosen and remove the screws. Remove the cover damper, bracket, and screws and set them aside.
Installing the replacement cover damper
Overview: Mount and secure the replacement printer cover damper.
Step 1: Insert the cover damper into its bracket
Orient the replacement cover damper with the piston section facing up. Slide the cover damper into the cover damper bracket.
Step 2: Mount and secure the cover damper
Place the rounded portion of the cover damper bracket into the slot in the side of the Z-tower. Align the four screw holes in the replacement cover damper bracket with the corresponding holes in the printer’s Z-tower. Thread one cover damper bracket screw into each of the four screw holes. Use a 2.5 mm hex driver to tighten until snug.
Reinstalling the back panel
Overview: After replacing the cover damper, reinstall and secure the back panel.
Step 1: Close the printer cover
Close the printer cover before reinstalling the back panel.
Step 2: Mount the back panel
Slide the top edge of the back panel under the cover bracket. Ensure that the eight screw holes in the back panel align with the corresponding holes in the printer and the back panel sits flush with the sides of the cover.
Step 3: Secure the back panel
Thread one back panel screw into each of the eight screw holes in the back panel. Use a 2.5 mm hex driver to tighten until snug.
Finalizing the repair
Overview: After installing the new cover damper, power on the printer and perform final checks.
Step 1: Power on the printer
Step 2: Test the cover
Open and close the cover several times. Check that it moves smoothly and the printer properly detects when the cover is open or closed. Contact Formlabs Support or your authorized reseller to share the results of the procedure.
