Required Supplies:
- Resin tank RFID board
- 2.5 mm hex driver (included in the Form 4 tool caddy)
Third-party:
- Nitrile gloves
- 2 mm hex driver
The resin tank RFID board sits on the left side of the Z-tower and detects the presence of the resin tank on Form 4 generation printers. A malfunctioning resin tank RFID board may prevent the printer from recognizing resin tanks and printing properly.
Use this guide to replace the Form 4 resin tank RFID board.
Required Supplies:
Third-party:
Estimated time: 30 minutes
Preparing the workspace
Overview: Prepare the printer and a dust-free workspace for removing the resin tank RFID board.
Remove the build platform first to avoid dripping resin onto the Light Processing Unit (LPU).
Step 3: Remove and store the resin tank and mixer
Step 4: Prepare the workspace
Step 5: Clean the printer
Warning:
Open the printer cover and clean any resin pooled on and around the LPU with non-abrasive wipes. Dampen the wipes with isopropyl alcohol if necessary to fully remove the resin.
Danger:
Step 6: Unplug the printer
Danger:
Performing maintenance on the printer while it is plugged in increases the risk of electric shock. Never remove the printer panels while the printer is plugged in. Never reconnect the printer to power while the panels are uninstalled.
Removing the back panel
Overview: Remove the back panel to access the resin tank RFID board.
Formlabs printers contain sensitive electronic components. Ground yourself before touching any electronics in the printer by using a grounding strap or touching a grounded piece of metal.
Step 1: Remove the back panel screws
Use a 2.5 mm hex driver to remove the eight screws securing the back panel to the printer. Set the screws aside.
Step 2: Remove the back panel
Remove the back panel by sliding it down and away from the back of the printer. Set the back panel aside.
Removing the resin tank RFID board
Overview: After preparing the printer and workspace, remove the RFID board.
Step 1: Remove the resin tank RFID bracket screws
Use the 2.5 mm hex driver to remove the two screws that secure the resin tank RFID bracket to the Z-tower. Set the screws aside.
Step 2: Remove the resin tank RFID bracket
Grip the top edge of the resin tank RFID bracket. Lift the bracket slightly, then carefully pull the resin tank RFID bracket towards you. Rotate the bracket until the RFID board is visible. Do not pull the
Step 3: Remove the resin tank RFID board mounting screws
Use a 2 mm hex driver to remove the two screws that secure the resin tank RFID board to the metal bracket. Set the screws aside.
Step 4: Disconnect the resin tank RFID cable
While holding the resin tank RFID board, squeeze the plastic retaining clip and unplug the resin tank RFID cable from the board. Do not pull on the wires.
Step 5: Remove the resin tank RFID board
Once the cable is unplugged, the resin tank RFID board is separated from the printer. Set the RFID board aside for disposal with electronics waste.
Installing the replacement resin tank RFID board
Overview: Mount and secure the replacement resin tank RFID board.
Step 1: Connect the resin tank RFID cable
Connect the resin tank RFID cable to the replacement board. The connector makes an audible and tactile click when secured.
Step 2: Mount the resin tank RFID board to the bracket
Align the mounting posts on the replacement resin tank RFID board with the screw holes on the resin tank RFID bracket. Thread one resin tank RFID board mounting screw into both of the two screw holes. Use a 2 mm hex driver to tighten the two screws until finger tight.
Step 3: Secure the resin tank RFID bracket to the printer
Align the resin tank RFID bracket with the two screw holes in the Z-tower. Make sure that the board sits neatly next to the Z-tower and that the cables lie neatly. Thread the resin tank RFID bracket retention screws into the screw holes. Use a 2 mm hex driver to tighten the two screws until finger tight.
Reinstalling the back panel
Overview: After replacing the resin tank RFID board, reinstall and secure the back panel.
Step 1: Mount the back panel
Slide the top edge of the back panel under the cover bracket. Ensure that the eight screw holes in the back panel align with the corresponding holes in the printer and the back panel sits flush with the sides of the cover.
Step 2: Secure the back panel
Thread one back panel screw into each of the eight screw holes in the back panel. Use a 2.5 mm hex driver to tighten until snug.
Finalizing the repair
Overview: After installing the new resin tank RFID board, power on the printer and perform final checks.
Step 1: Power on the printer
Connect the power cable to the printer and the power supply. The printer initializes. Check that the printer initializes normally and does not display any error messages.
Step 2: Test the resin tank RFID board
Insert a resin tank and check that the printer recognizes it properly. Repeat with other resin tanks if any are available. Contact Formlabs Support or your authorized reseller to share the results of the procedure.
