Replacing the Form 4L Light Processing Unit fan
The Light Processing Unit (LPU) fans cool the Form 4L optical system. Damage to the LPU fans may cause the optical system to overheat and prevent the printer from functioning properly.
Use this guide to replace one or both of the LPU fans.
Required Supplies:
  • Light Processing Unit cooling fan
  • 2.5 mm hex driver (included in the Form 4L tool caddy)
  • 3 mm hex driver (included in the Form 4L tool caddy)
Third-party:
  • Nitrile gloves
Estimated time: 20–30 minutes
Preparing the workspace
Overview: Prepare the Form 4L and a dust-free workspace for replacing the LPU cooling fan
Remove the build platform first to avoid dripping resin onto the Light Processing Unit (LPU).
Step 2: Remove the resin cartridges
Remove the resin cartridges and close the vent caps to prevent resin from dripping off of the bite valves and into the printer.
Step 3: Remove and store the resin tank and mixer
NOTICE:
Step 4: Prepare the workspace
Step 5: Clean the printer
WARNING:
Open the printer cover and clean any resin pooled on and around the LPU with non-abrasive wipes. Dampen the wipes with isopropyl alcohol if necessary to fully remove the resin.
DANGER:
Step 6: Unplug the printer
DANGER:
Performing maintenance on the printer while it is plugged in increases the risk of electric shock. Never remove the printer panels while the printer is plugged in. Never reconnect the printer to power while the panels are uninstalled.
Removing the LPU cooling fan
Overview: Remove the LPU cooling fan that is being replaced.
Step 1: Remove the mesh filter
Remove the mesh filter from the right side of the printer. Set the filter aside.
Step 2: Remove the lower right panel
Use a 2.5 mm hex driver to remove the four screws securing the lower right panel to the printer. Remove the screws and the panel and set them aside.
Step 3: Remove the LPU fan filter
Disengage the fan retainer by pulling downwards and swinging the wire arm towards you. Remove the LPU fan filter by pulling straight down on the filter’s body. Set the filter aside.
Step 4: Remove the filter mount
Use a 3 mm hex driver to remove the three screws securing the filter mount to the printer. Remove the filter mount and screws and set them aside.
Step 5: Remove yellow tape
Peel off the tape that goes around the fan duct and temporarily stick it on a clean surface.
Step 6: Unhook the cable harness
A cable harness is held in place with bendable cable ties. Bend the cable ties to unhook the harness.
Step 7: Remove the LPU fan
Use a 2.5 mm hex driver to remove the three screws securing the LPU fan that you are replacing. The bendable cable tie is secured to the fan by one of the three screws—remove the cable tie and set it aside with the fan screws.
Step 8: Disconnect the LPU fan cable
Remove the fan from the printer and locate the LPU fan cable connector behind it. Release the cable that connects to the LPU fan by pressing on the plastic tab on the connectors. Take care when unplugging the cable to avoid damage. Once the plastic tab is pressed, the cable easily slides from the connector. Do not pull on the wires.
Step 9: Remove the other LPU fan (optional)
If you are replacing both fans, repeat steps 7–8 for the other fan.
Install the replacement LPU cooling fan
Overview: Mount and secure the replacement LPU cooling fan.
Step 1: Orient the replacement fan
Orient the replacement fan to fit in its mounting location within the printer. The front and back cooling fans are the same part in two different orientations.
Step 2: Connect the LPU fan cable
Reconnect the cable that connects the LPU fan to the printer. The plastic tabs should click into place to secure the connection. Take care not to pull on the wires.
Step 3: Install the LPU fan
Place the fan into the printer, aligning the screw holes in the fan with the corresponding screw holes in the printer frame. Install the black cable tie onto the replacement fan at the same screw hole as on the old fan. Thread one screw into each of the three screw holes, then use a 2.5 mm hex driver to tighten until snug. Take care not to pinch or crush the wiring behind the fan.
Step 4: Install the other replacement LPU fan (optional)
If you are replacing both fans, repeat steps 1–3 for the other fan.
Step 5: Hook the cable harness
Secure the cable harness away from the fan blades by bending the black cable ties around the wires.
Step 6: Replace the yellow tape
Replace the yellow tape around the fan duct.
Step 7: Install the filter mount
Place the filter mount over the LPU fans, aligning the screw holes in the mount with the corresponding screw holes in the printer frame. Thread one screw into each of the three screw holes, then use a 3 mm hex driver to tighten until snug.
Step 8: Install the LPU fan filter
Slide the fan filter under the wire filter retainer and push upwards until fully seated. Pull downwards on the filter retainer and swing it beneath the filter to secure the filter in place.
Step 9: Mount and secure the lower right panel
Align the screw holes in the lower right panel with those in the printer frame. Thread one mounting screw into each of the four screw holes. Use a 2.5 mm hex driver to tighten until snug.
Step 10: Reinstall the mesh filter
Place the mesh filter over the grate on the right side of the printer.
Finalizing the repair
Overview: After installing the new LPU cooling fan, power on the printer and perform final checks.
Step 1: Power on the printer
Close the printer door and connect the power cable to the printer and the power supply. Turn on the switch at the back of the printer. The printer will turn on and initialize.
Step 2: Run a test print
Insert any missing consumables and upload and start a print. Perform a small test print to ensure that the printer works normally. Contact Formlabs Support or your authorized reseller to share the results of the procedure.
