Replacing the Fuse 1 generation interlock board
Fuse 1 generation printers use a variety of interlock sensors to ensure that the required printer doors are closed before starting or continuing a print. A faulty or malfunctioning interlock board could prevent the printer from determining the state of its doors, leading to unexpected behavior.
Use this guide to replace the interlock board on a Fuse 1 generation printer.
Required supplies:
  • Replacement Fuse 1 generation interlock board
Third-party:
  • 2.0 mm hex driver (flat-end)
  • Nonreactive nitrile gloves
  • N95 or better respirator
Estimated time: 15–20 minutes
Danger:
Warning:
Preparing the workspace
Overview: Prepare the printer and a dust-free workspace for replacing the air heater.
Step 1: Prepare the workspace
Step 2: Unplug the printer
Danger:
Remove the inner-right enclosure panel
Overview: Remove the inner-right enclosure panel to access the interlock board.
Step 1: Open the print enclosure door
Open the filter cabinet door, then pull the blue handle to manually open the print enclosure door.
Step 2: Remove the inner-right enclosure panel retention screws.
Using a 2.5 mm hex driver, loosen and remove the 12.0 mm M4 countersunk screw on the hopper side of the printer. Use the same driver to loosen and remove the six 5.0 mm black M4 dome screws on the front of the inner-right enclosure panel. Set the screws aside.
Step 3: Remove the inner-right enclosure panel
Separate the inner-right enclosure panel from the printer and set it aside.
Removing the interlock board
Overview: Disconnect and remove the original interlock board.
Step 1: Remove the interlock board retention screws
Using a 2.0 mm hex driver, loosen and remove the four 5.0 mm stainless M3 button screws securing the interlock board to the printer. Do not pull the board away from the printer, as it is still attached via three cables.
Remove and replace the interlock board
Step 2: Disconnect and remove the interlock board
Turn the interlock board over to reveal three JST cable connectors. Disconnect the JST connectors from the board by depressing the white locking tab, then pulling the connector housing away from the receptacle. Set the original interlock board aside for disposal.
Installing the replacement interlock board
Overview: Connect mount, and secure the replacement interlock board.
Step 1: Connect the interlock cables to the interlock board
Remove the new interlock board from its packaging. Orient the board to that the Formlabs logo is right-side up. Connect the three JST connectors to the corresponding receptacles on the new interlock board.
Step 2: Mount the interlock board
Turn the interlock board over and nest the cable harnesses into the clearance hole behind the interlock board’s mounting points. Align the screw holes in the board with the corresponding standoffs on the printer frame.
Step 3: Secure the interlock board
Thread one 5.0 mm stainless M3 button head screw into each of the four screw holes in the interlock board. Using a 2.0 mm hex driver, tighten the screws until snug.
Reinstalling the inner-right enclosure panel
Overview: After installing the new interlock board, reinstall the inner-right enclosure panel.
Step 1: Mount the inner-right enclosure panel
Hold the inner-right enclosure panel up to the printer frame, aligning the seven screw holes in the panel with the corresponding screw holes in the front and side of the printer frame.
Step 2: Secure the inner-right enclosure panel
Replace the inner-right enclosure panel
Thread one 5.0 mm black M4 button head screw into each of the six screw holes in the front of the inner-right enclosure panel. Thread the 12.0 mm M4 countersunk screw into the screw hole on the hopper side of the printer. Using a 2.5 mm hex driver, tighten all seven screws until snug.
Step 3: Close the printer doors
Close the print enclosure and filter cabinet doors.
Finalizing the repair
Overview: After installing the replacement interlock board, power on the printer and perform final checks.
Step 1: Power on the printer
Step 2: Test the repair
Open the print enclosure door using the touchscreen. Close the door and check that the touchscreen responds appropriately. Contact Formlabs Support or your certified service provider to share the results of the procedure.
