Replacing the Fuse Sift motherboard
The motherboard is the main electronics module on the Fuse Sift that controls various subsystems. The motherboard is located in an enclosure at the back of the machine. A malfunctioning motherboard may prevent the printer from printing properly.
Use this guide to replace the Fuse Sift motherboard.
This procedure applies exclusively to Fuse Sift units manufactured after June 22nd, 2021 running Fuse Sift firmware version 1.4.3 or later prior to replacing the motherboard. A Fuse Sift is ineligible for motherboard replacement if it was manufactured before June 22nd, 2021 or is unable to successfully update its firmware to version 1.4.3 or later. If a firmware version older than 1.4.3 is installed when the motherboard is replaced, the Fuse Sift will display an error message stating that the new motherboard's signature is unrecognized.
Required supplies:
Third-party:
  • 1.3 mm hex driver (flat-end)
  • #2 Phillips screwdriver
  • ESD-safe spudger (recommended) or ESD-safe tweezers
  • Antistatic wristband
  • Appropriate personal protective equipment for the powder in use, as defined in the safety data sheet (SDS)
  • Loctite 243 or equivalent threadlocker
  • Computer with PreForm
  • WAN internet connection
  • USB A to B cable
Estimated time: 30–45 minutes
Preparing the machine
Overview: Before replacing the Fuse Sift motherboard, check its firmware version and update if needed.
Step 1: Check the firmware version
On the Fuse Sift touchscreen, tap Settings > System > Firmware Version.
Step 2: Update firmware
If the version installed is older than version 1.4.3, update the firmware to the latest version available prior to replacing the motherboard.
Removing the rear enclosure panel
Overview: Remove the rear enclosure panel to better access the cartridge drawer components.
Step 1: Unplug the Fuse Sift
Power off the Fuse Sift, then unplug the power cable from the rear panel.
Danger:
Performing this procedure on the Fuse Sift while it is plugged in increases the risk of electric shock. After disconnecting the power from the Fuse Sift, wait at least five minutes before servicing.
Step 2: Unscrew the Wi-Fi antenna
Remove the Wi-Fi antenna, if present.
Step 3: Remove the rear enclosure panel
Use a 2.5 mm hex driver to remove the 16 black 8.0 mm M4 screws securing the rear panel to the Fuse Sift. Set the rear enclosure panel aside.
Fuse sift rear enclosure panel
Tip
Remove the top three screws last to prevent the panel from falling off.
The Fuse Sift contains sensitive electronic components. Ground yourself before touching any electronics in the device by using an antistatic wrist band.
Removing the motherboard
Overview: Open the motherboard enclosure and disconnect and remove the original motherboard.
Step 1: Prepare to replace the motherboard
Put on an antistatic wristband and connect it to a known ground point. Do not connect the wristband any surfaces that are powder-coated or painted.
Step 2: Remove the motherboard cover
Locate the square motherboard cover on the rear of the machine. Using a #2 Phillips driver, loosen and remove the eight countersunk screws securing the cover onto the motherboard enclosure. Set the screws and cover aside.
Remove the original motherboard
Step 3: Disconnect the cables from the motherboard
For your reference and for easier reinstallation, take a picture of the motherboard with all cables clearly visible. Disconnect all cables from the motherboard.
Remove the existing MoBo
Step 4: Disconnect the Wi-Fi antenna cable from the system on module (SOM)
Use a pair of ESD-safe tweezers to disconnect the Wi-Fi coaxial connector from the SOM. Take care when handling the cable and connector, as both are very fragile.
Step 5: Unscrew the motherboard mounting screws
Using a 2.5 mm hex driver, loosen and remove the six 10.0 mm M4 screws securing the motherboard to its enclosure. Set the screws aside.
Step 6: Remove the motherboard
Carefully remove the motherboard from the Fuse Sift and set it aside on a flat, clean, anti-static work surface.
Removing the SOM
Overview: Uninstall the SOM from the original motherboard to transfer to the replacement motherboard.
Step 1: Remove the SOM retention screws
Using a 1.5 mm hex driver, loosen and remove the two 5 mm M2 socket head screws securing the SOM to the motherboard. Set the screws aside.
Remove the SOM
Step 2: Locate the SOM retention tabs
Remove the SOM
Remove the SOM
Locate the two retention tabs (one on each side) securing the SOM to the motherboard.
Step 3: Open the retention tabs
Use an ESD-safe spudger or a pair of ESD-safe tweezers to disengage the retention tabs by flexing them outwards slightly. The end of the SOM opposite the socket may lift up slightly.
Remove the SOM
Step 4: Remove the SOM
Gently grip the SOM by the heat sink, pivot it upwards at approximately a 30º angle, then pull it straight away from the motherboard. Set the SOM aside.
Remove the SOM
Installing the SOM into the replacement motherboard
Overview: Insert the SOM into its slot on the replacement motherboard and secure it in place.
Step 1: Prepare the replacement motherboard
Remove the replacement motherboard and place it on a flat, clean, anti-static work surface.
Step 2: Insert the SOM into its socket
Install the replacement SOM
Pick up the SOM by the heatsink, then insert it into the socket on the motherboard at approximately a 30º angle. Gently push the SOM into the socket so that none of the gold pins on the SOM are visible.
Step 3: Secure the SOM with the retention tabs
Push the SOM down onto the motherboard until the retention tabs snap into place.
Step 4: Fully secure the SOM
Thread one 5.0 mm M2 screw into both of the two screw holes in the SOM. Using a 1.5 mm hex driver, tighten until finger-tight.
Installing the replacement motherboard
Overview: After transferring the SOM, mount, secure, and connect the replacement motherboard.
Step 1: Check the replacement motherboard
Inspect the replacement motherboard and make sure that the battery and electrical fuse are already installed. If they are not, remove them from the original board and install them on the replacement board.
Install the replacement MoBo
Step 2: Mount the motherboard
Orient the motherboard with the battery on top and the fuse on the right. Place the replacement motherboard in the Fuse Sift motherboard enclosure, aligning the six screw holes in the motherboard with the corresponding screw holes in the enclosure standoffs.
Step 3: Partially secure the motherboard
Thread one 10.0 mm M4 screw into the left and center screw holes in the motherboard, circled in red here. Leave the two right-hand screw holes empty. Using a 2.5 mm hex driver, tighten the four screws until snug.
Step 4: Reconnect the grounding wires
Place the black ground wire ring terminal over the top-right motherboard screw hole. Secure the ground wire to the motherboard using a 10.0 mm M4 screw. Using a 2.5 mm hex driver, tighten until snug.
Place the green and green/yellow ground wire ring terminals over the bottom-right motherboard screw hole. Secure the ground wires to the motherboard using a 10.0 mm M4 screw. Using a 2.5 mm hex driver, tighten until snug.
Step 5: Reconnect the Wi-Fi antenna cable
Use a pair of ESD-safe tweezers to reconnect the Wi-Fi coaxial connector to the SOM. Take care when handling the cable and connector, as both are very fragile.
Step 6: Connect the motherboard cables
Reconnect all cable connectors to their respective sockets on the replacement motherboard. Refer to the image here to match each connector with its socket.
The display cable socket (labeled CBL-103937) on the motherboard is very delicate. Do not force the connector into the socket, or the replacement motherboard may be damaged.
Step 7: Reinstall the motherboard cover
Place the motherboard cover onto the motherboard enclosure, aligning the screw holes in the cover with the corresponding one around the edge of the enclosure. Thread one mounting screw into each of the eight screw holes, then use a #2 Phillips screwdriver to tighten until snug.
Replace the MoBo enclosure cover
Reinstalling the rear enclosure panel
Overview: Mount and secure the rear enclosure panel after installing the new display assembly and cable.
Step 1: Prepare the rear panel retention screws
Apply a small amount of Loctite 243 or other similar threadlocker to each of the 16 black 8.0 mm M4 button screws that secure the rear panel to the Fuse Sift.
Step 2: Mount the rear panel
Mount the rear panel onto the Fuse Sift.
Step 3: Secure the rear panel
Thread one 8.0 mm M4 button screw into each of the 16 screw holes in the rear panel. Use a 2.5 mm hex driver to tighten until snug.
Tip:
Start with the top three screws to hold the panel in place while you thread and tighten the remaining screws.
Finalizing the repair
Overview: After installing the new motherboard, power on the Fuse Sift and test its functions.
Step 1: Power on the Fuse Sift
Reconnect the Fuse Sift to its power source. Flip the power switch to the ON position.
Update the firmware to the latest version available. If the machine is on the latest firmware, manually reinstall it.
Step 3: Test the machine
Check that the Fuse Sift fully boots. Test various functions to ensure the machine works as expected. Contact Formlabs Support or your certified service provider to share the results of the procedure.
