Starting a print job on the printer touchscreen
When the print job upload is complete, the FORM file is saved to the printer’s internal storage. Print jobs can be deleted at any time to free up space on the printer.
Once transferred from PreForm to the printer, print jobs must be confirmed on the printer’s touchscreen to start the print.
Start the print job directly after uploading it to your printer or access the print job at a later stage from Jobs (Form 2) or Queue (other Formlabs SLA printers).
Starting a print job on a Form 2
To start a print job on a Form 2:
  1. Tap the print job from the home screen, or from Jobs. A new screen appears.
  2. Tap Print Now to confirm. A new screen appears.
  3. Follow the prompts on the touchscreen to check consumables are inserted correctly, then press the push button. The print starts.
Starting a print job on a Form 3 or Form 3L generation printer
To start a print job on a Formlabs LFS printer (Form 3 or later):
  1. Tap the print job from the Home screen, or from Queue. A new screen appears.
  2. Tap Print to confirm. A new screen appears.
  3. Follow the prompts on the touchscreen to check consumables are inserted correctly, then tap Confirm. The print starts.
Tip:
Prime your Formlabs printer before sending a file to immediately begin printing without the need to confirm on the touchscreen.
Starting a print job on a Form 4 or Form 4L generation printer
To start a print on a Form 4 or Form 4L generation printer, you can use the Queue or History list.
Starting from the Queue
When you send a job from PreForm, the job is automatically added to the Queue.
  1. Locate the print job you want to reprint.
  2. Tap the Start Print button next to the job in the Queue. The Printing screen appears and the print starts.
Starting from the History list
Previously-completed jobs can be viewed in the History list.
  1. Swipe up on the Queue to view the History list.
  2. Locate the print job you want to reprint.
  3. Tap the Add to Queue button next to the job. The job is added to the bottom of the Queue.
  4. Tap the Start Print button next to the job in the Queue. The Printing screen appears and the print starts.
