Understanding dental application print speed (Form 4B)
Form 4 generation printers deliver blazing fast print speeds with excellent reliability, print quality, accuracy, materials performance, and build volume size. Most MSLA printers sacrifice one or several aspects of print performance to achieve comparable speeds.
Print speed is mostly impacted by material and layer height and slightly impacted by print geometry. The most accurate way to calculate the print time for your model is by using the Print Time estimation feature in PreForm, our free print preparation software.
The tables below show print speeds for a variety of dental applications, resins, and numbers of models per print. For general information about Form 4 generation print speeds, see Understanding print speed (Form 4 generation).
Tip:
Click each image for a full-size view.
Multiple parts per print
ApplicationResinLayoutLayer thickness (microns)Number of parts/jobMax job height (mm)Print time (min)1Print time per part (min)Print speed (mm/hr)
Clear aligner modelsFast Model11 aligner models in Fast Model Resin on a Form 4B160111290.880.0
Occlusal splints and guardsDental LT Comfort8 occlusal splint models in Dental LT Comfort Resin on a Form 4B100827.2577.128.6
Occlusal splints and guardsDental LT Clear V28 occlusal splint models in Dental LT Clear Resin V2 on a Form 4B100827.2546.830.2
Restorative modelsPrecision Model10 restorative models in Precision Model Resin on a Form 4B501022.811211.212.2
Surgical guidesSurgical Guide12 surgical guide models in Surgical Guide Resin on a Form 4B1001224.9484.031.1
All-on-XPremium Teeth9 all-on-X models in Premium Teeth Resin on a Form 4B100927.4374.144.4
Crowns and bridgesPremium Teeth5 crown and bridge models in Premium Teeth Resin on a Form 4B100521.8255.052.3
Indirect bonding traysIBT Flex8 indirect bonding tray models in IBT Flex Resin on a Form 4B100810.2546.811.3
Denture teethPremium Teeth10 denture models in Premium Teeth Resin on a Form 4B1001019272.742.2
Denture baseDenture Base6 denture models in Denture Base Resin on a Form 4B50630.710016.718.4
Custom impression traysCustom Tray4 custom impression tray models in Custom Tray Resin on a Form 4B100435.14812.043.9
Diagnostic modelsGrey V56 diagnostic models in Grey Resin V5 on a Form 4B100615.7345.727.7
Patterns for casting and pressingCastable Wax16 patterns for casting and pressing in Castable Wax Resin on a Form 4B1002618.81244.89.1
Soft tissueFlexible 80A26 soft tissue models in Flexible 80A Resin on a Form 4B1002618.81244.89.1
Hawley retainer modelsGrey V58 Hawley retainer models in Grey Resin V5 on a Form 4B100819.1475.924.4
Direct composite restorationIBT Flex12 direct composite restoration models in IBT Flex Resin on a Form 4B1001242.913411.219.2
Crowns and bridgesBEGO™ VarseoSmileⓇ TriniQⓇ Resin30 crown and bridge models in BEGO™ VarseoSmileⓇ TriniQⓇ Resin on a Form 4B503023.151595.38.7
Permanent restorationsBEGO™ VarseoSmileⓇ TriniQⓇ Resin48 permanent restoration models in BEGO™ VarseoSmileⓇ TriniQⓇ Resin on a Form 4B504820.151473.18.2
1 Using PreForm 3.37.1
Single part per print
ApplicationResinLayoutLayer thickness (microns)Max job height (mm)Print time (min)1Print speed (mm/hr)
Clear aligner modelsFast ModelAligner model in Fast Model Resin on a Form 4B16012890.0
Occlusal splints and guardsDental LT ComfortOcclusal splint model in Dental LT Comfort Resin on a Form 4B10027.24834.0
Occlusal splints and guardsDental LT Clear V2Occlusal splint model in Dental LT Clear Resin V2 on a Form 4B10027.24734.7
Restorative modelsPrecision ModelRestorative model in Precision Model Resin on a Form 4B5022.88516.1
Surgical guidesSurgical GuideSurgical guide model in Surgical Guide Resin on a Form 4B10024.94136.4
All-on-XPremium TeethAll-on-X model in Premium Teeth Resin on a Form 4B10027.43054.8
Crowns and bridgesPremium TeethCrown model in Premium Teeth Resin on a Form 4B10016.12048.3
Indirect bonding traysIBT FlexIndirect bonding tray model in IBT Flex Resin on a Form 4B10010.23816.1
Denture teethPremium TeethDenture model in Premium Teeth Resin on a Form 4B100192349.6
Denture baseDenture BaseDenture model in Denture Base Resin on a Form 4B5030.76926.7
Custom impression traysCustom TrayCustom tray model in Custom Tray Resin on a Form 4B10035.13954.0
Diagnostic modelsGrey V5Diagnostic model in Grey Resin V5 on a Form 4B10015.72636.2
Patterns for casting and pressingCastable WaxPattern for casting and pressing in Castable Wax Resin on a Form 4B5035.4515713.5
Soft tissueFlexible 80ASoft tissue model in Flexible 80A Resin on a Form 4B10018.86617.1
Hawley retainer modelsGrey V5Hawley retainer model in Grey Resin V5 on a Form 4B10019.13235.8
Direct composite restorationIBT FlexDirect composite restoration model in IBT Flex Resin on a Form 4B10042.99228.0
Permanent restorationsBEGO™ VarseoSmileⓇ TriniQⓇ ResinPermanent restoration model in BEGO™ VarseoSmileⓇ TriniQⓇ Resin on a Form 4B10020.23435.6
Permanent restorationsBEGO™ VarseoSmileⓇ TriniQⓇ ResinPermanent restoration model in BEGO™ VarseoSmileⓇ TriniQⓇ Resin on a Form 4B5020.210112.0
