What happens when Formlabs retires a material formulation?
Formlabs will give at least three months of notice before retiring a material during which users can still make ongoing purchases. Depending on material popularity, the sunsetting period may be longer than three months to give users more time to transition. When a new version of a material is released, both versions will be sold in parallel for a period of time. In some cases, a material may be retired without a direct replacement available.
If the new version of a material is only supported on the newest generation of printer, the old version of the resin will remain available on the legacy printer generation for as long as the printer is actively supported, or Formlabs cannot support making the material anymore.
Example: Formlabs releases Tough 1500 Resin V2, which is only compatible with Form 4 generation printers.
  • Tough 1500 Resin V1.1 is sunset on Form 4 generation printers since it is replaced by a new version.
  • Tough 1500 Resin V1 remains on Form 3 generation printers for as long as there is ongoing support for that generation of hardware.
Formlabs material sunsetting roadmap (2023 to present)
Material Compatible printersLast available dateReplacement materialReplacement available on:
Dental LT Clear Resin V1Form 3/B/+
Form 2
12/1/23Dental LT Clear Resin V2Form 4B
Form 3B/L/+
Form 2
Ceramic Resin V1Form 212/31/23Alumina 4N Resin V1Form 4/B
Form 3/B/+
Denture Teeth Resin V1Form 3/B/+
Form 2
12/3/24Premium Teeth Resin V1Form 4B/L
Form 3B/+
Form 2
Elastic 50A Resin V1Form 3/B/L/+
Form 2
3/17/25Elastic 50A Resin V2Form 4/B/L
Form 3/B/L/+
Polypropylene Powder V1Fuse 1+ 30W5/16/2025NoneN/A
PU Rigid 650 Resin V1Form 3/B/L/+
Form 2
8/8/2025NoneN/A
PU Rigid 1000 Resin V1Form 3/B/L/+
Form 2
8/8/2025NoneN/A
Black Resin V4Form 3/B/L/+
Form 2
12/31/2025Black Resin V4.1Form 3/B/L/+
Clear Resin V4Form 3/B/L/+
Form 2
12/31/2025Clear Resin V4.1Form 3/B/L/+
White Resin V4Form 3/B/L/+
Form 2
12/31/2025White Resin V4.1Form 3/B/L/+
Tough 1500 Resin V1.1Form 4/B/L12/31/2025Tough 1500 Resin V2Form 4/B/L
Temporary CB Resin V1Form 3B/+3/1/2026Premium Teeth Resin V1Form 4B/L
Form 3B/+, Form 3BL
BEGO™ VarseoSmile® TriniQ® Resin V1Form 4B
Permanent Crown Resin V1Form 3B/+3/1/2026BEGO™ VarseoSmile® TriniQ® Resin V1Form 4B
Castable Wax 40 Resin V1Form 3/B/+3/1/2026True Cast Resin V1Form 4/B
Castable Wax Resin V1Form 4/B/L
Form 3/B/L/+
Grey Resin V4Form 3/B/L/+
Form 2
3/31/2026Grey Resin V4.1Form 3/B/L/+
Tough 2000 Resin V1.1Form 4/B/L8/31/2026Tough 2000 Resin V2Form 4/B/L
Durable Resin V2.1Form 4/B/L8/31/2026Tough 1000 Resin V1Form 4/B/L
