What is the build volume of the Fuse 1?
Due to varying thermal expansion rates for different materials, the largest parts size printable in the Fuse Series printers varies. The largest part sizes achievable are given in the table below.
Note:
The corners of the Fuse 1 generation build chamber are rounded. In PreForm, the inner radius of the corner is 16 mm. As a result square part that fully spans the build chamber in the X and Y directions will not be printable.
MaterialLargest Part Size
Nylon 12 Powder159.8 × 159.8 × 295.5 mm
Nylon 12 GF Powder160.1 × 160.1 × 297.3 mm
Nylon 12 Tough Powder158.8 × 158.8 × 293.5 mm
Nylon 12 White Powder159.8 × 159.8 × 293.8 mm
Nylon 11 Powder158.6 × 158.6 × 294.4 mm
Nylon 11 CF Powder162.0 × 162.0 × 287.6 mm
TPU 90A Powder152.1 × 152.1 × 294.9 mm
Polypropylene Powder159.4 × 159.4 × 296.0 mm
Tip:
Check the design specifications for the Fuse 1 before designing your model.
