Remove all packaging material before connecting power. Retain all packaging and inserts for warranty service. Refer to the manual for the repackaging instructions.
Plan an appropriate location for the Form Studio Wash+Cure. Purchase additional finishing supplies, including a suitable washing solvent, to ensure you can start using the Form Studio Wash+Cure when it arrives.
The Form Studio Wash+Cure switches modes based on whether the turntable or wash bucket is installed
Additional supplies
Purchase the following additional supplies:
Arranging the workspace
The Form Studio Wash+Cure has the following dimensions: 33 × 30 × 44 cm (13 × 11.8 × 17.3 in). The unit weighs 9 kg (19.8 lb).
Reserve the following minimum dimensions for the most convenient access:
Operate the Form Studio Wash+Cure in a well-ventilated room with a temperature of 18—28 °C (64—82 °F). Follow all guidance in the Safety Data Sheet (SDS) provided by the manufacturer of your solvent.
Unboxing the Form Studio Wash+Cure
The Form Studio Wash+Cure ships in a cardboard carton, protected by foam inserts above and below the machine. During unboxing, inspect the machine for any damage or missing items. In the case of damage or missing items, contact Formlabs Support or your authorized reseller.
To unbox the Form Studio Wash+Cure:
Form Studio Wash+Cure components
Installing the Form Studio Wash+Cure
Place the Form Studio Wash+Cure on a clean, level surface with a nearby power source.
The Form Studio Wash+Cure is ready for use for part washing once the wash bucket has been filled between the minimum and maximum (10 L) fill lines. Choose whether to wash the part on the build platform or in the basket.
Connect the power supply
Connect the power cable and external supply to the Form Studio Wash+Cure and a power source.
Fill the wash bucket with solvent
To fill the Form Wash:
