The Print Settings Editor is where you create and manage the custom print settings used for open materials.
To open the Print Settings Editor in PreForm, click Edit > Print Settings Editor. The Print Settings Editor window appears. Here, you can create, edit, export, import, and delete custom print settings. You can also browse Formlabs' built-in settings under the Formlabs Settings tab. Use the dropdown filters and search box to find a setting by printer, material, or layer thickness.
To create a new print setting for a third-party material, click New Print Setting > Open Material > Copy & Edit Selected.
