Using BioMed Amber Resin
BioMed Amber Resin is a rigid material for biocompatible applications requiring long-term topical skin or short-term mucosal membrane contact. BioMed Amber Resin can be sterilized by autoclave, E-beam, gamma, and ethylene oxide.
alt text
Note:
To learn more about the performance or specific material properties of BioMed Amber Resin, please refer to the Safety Data Sheet (SDS) and Technical Data Sheet (TDS). Always consult the SDS as the primary source of information to understand safety and handling of Formlabs materials.
 BioMed Black ResinBioMed White ResinBioMed Clear ResinBioMed Amber Resin
Can be sterilized
Transparent
Can be polished
Compatible with Form 2
Compatible with Form 3B/3B+//3BL
CertificationsUSP Class VI
ISO 10993-5, -10,-23
USP Class VI
USP <151> Pyrogen + ISO 10993-11 Acute systemic Toxicity Testing
USP Class VI
ISO 18562-1,-2,-3,-4
ISO 13485
Layer thickness50 microns
100 microns
50 microns
100 microns
50 microns
100 microns
50 microns
100 microns
Ultimate tensile strength (MPa)35.745.85273
Tensile modulus (GPa)1.52.02.12.9
Elongation at break (%)14101212.3
Flexural modulus (GPa)1.72.02.32.5
IZOD Impact strength (J/m)24.815.13528
Heat deflection temperature (HDT) @ 1.8 MPa49.452.45465
Heat deflection temperature (HDT) HDT @ 0.45 MPa (°C)68676778
Required resources
Made by Formlabs:
Printing with BioMed Amber Resin
For full compliance and biocompatibility, BioMed Amber Resin requires a dedicated resin tank, build platform, and Finish Kit which should not be used with any other resins.
  1. Open a model.
  3. Orient to preserve fine details.
  4. Generate supports.
Shake the BioMed Amber Resin cartridge for 5 minutes to ensure the resin is mixed completely. Insert the cartridge along with a resin tank and build platform, and start the print.
Finishing
The Form Wash agitates the solvent bath and removes parts from the bath after a set time. Wash parts according to the support article Form Wash time settings. Pay particular attention to information that affects mechanical properties or biocompatibility requirements.
Leave parts to air dry for at least 30 minutes to remove excess isopropyl alcohol (IPA) off part surfaces. Ambient humidity and thickness of printed parts can affect drying time as longer dry times are needed for thicker objects. A printed part that is not fully dry can affect autoclaving results. For optimal performance, dry larger and thicker parts overnight prior to post-curing.
Post-curing requirements
Post-cure parts to achieve biocompatibility and optimal mechanical properties. Refer to the support article Form Cure time and temperature settings for post-curing settings.
Additional resources
