Using BioMed Clear Resin
BioMed Clear Resin is a medical-grade material designed for rigid, non-brittle, biocompatible parts that require long-term skin and mucosal membrane contact and for end-use medical devices. It can be sterilized by autoclave, E-beam, gamma, and ethylene oxide.
Note:
To learn more about the performance or specific material properties of BioMed Clear Resin, please refer to the Safety Data Sheet (SDS) and Technical Data Sheet (TDS). Always consult the SDS as the primary source of information to understand safety and handling of Formlabs materials.
 BioMed Black ResinBioMed White ResinBioMed Clear ResinBioMed Amber Resin
Can be sterilized✔✔✔✔
Transparent  ✔✔
Can be polished✔✔✔✔
Compatible with Form 2✔✔✔✔
Compatible with Form 3B/3B+//3BL✔✔✔✔
CertificationsUSP Class VI
ISO 10993-5, -10,-23
USP Class VI
USP <151> Pyrogen + ISO 10993-11 Acute systemic Toxicity Testing
USP Class VI
ISO 18562-1,-2,-3,-4
ISO 13485
Layer thickness50 microns
100 microns
50 microns
100 microns
50 microns
100 microns
50 microns
100 microns
Supported with an FDA Device Master File, which assists customers’ medical device registrations. For more information, contact Sales at Formlabs.
Ultimate tensile strength (MPa)35.745.85273
Tensile modulus (GPa)1.52.02.12.9
Elongation at break (%)14101212.3
Flexural modulus (GPa)1.72.02.32.5
IZOD Impact strength (J/m)24.815.13528
Heat deflection temperature (HDT) @ 1.8 MPa49.452.45465
Heat deflection temperature (HDT) HDT @ 0.45 MPa (°C)68676778
Required resources
Made by Formlabs:
Printing with BioMed Clear Resin
For full compliance and biocompatibility, BioMed Clear Resin requires a dedicated resin tank, build platform, and Finish Kit which should not be used with any other resins.
Washing
Follow the part washing recommendations in the manufacturing guide for the clearest and best possible results. Improper washing can lead to suboptimal mechanical and biocompatibility properties.
Post-curing requirements
Follow the post-curing recommendations in the manufacturing guide for the clearest and best possible results. Improper post-curing can lead to suboptimal mechanical and biocompatibility properties.
  • Do not post-cure beyond the recommended post-cure settings, as this may cause discoloration.
  • Allow post-cured splints to cool completely before removing supports or fitting.
  • Remove supports only after post-curing to prevent parts from warping.
Additional resources
