BioMed Durable Resin is a clear material for applications requiring impact, shatter, and abrasion resistance. This USP Class VI material is made in an FDA-registered, ISO 13485 facility and can be used in applications for long-term skin (>30 days) and short-term tissue, bone, and dentin contact (<24hrs).
Recommended for:
BioMed Durable Resin prints at 100 microns.
| BioMed Durable Resin | BioMed Clear Resin | |
| Ultimate tensile strength (MPa) | 29.1 | 52 |
| Tensile modulus (MPa) | 994 | 2080 |
| Elongation at break (%) | 33 | 12 |
| Durometer/Shore Hardness | 75D | 78D |
| Flexural modulus (GPa) | 0.64 | 0.23 |
| IZOD Impact strength (J/m) | 98 | 35 |
To learn more about the performance properties of Formlabs resins, refer to the library of material properties data sheets.
Printing with BioMed Durable Resin
Finishing
The Form Wash agitates the solvent bath and removes parts from the bath after a set time. Wash parts according to the manufacturing guide. Pay particular attention to information that affects mechanical properties or biocompatibility requirements.
Post-curing requirements
BioMed Durable Resin requires post-curing to reach its optimal mechanical properties.
Refer to the support article Form Cure time and temperature settings for post-curing recommendations.
Follow post-curing recommendations from Formlabs for the clearest and best possible results. Improper post-curing can lead to suboptimal mechanical and biocompatibility properties.
Additional resources
