Using BioMed Flex 80A Resin
BioMed Flex 80A Resin is a firm, elastic, medical-grade material for applications requiring durability, biocompatibility, and transparency. This ISO 10993 and USP Class VI material is produced in an FDA-registered, ISO 13485 certified facility and can be used in applications with long-term skin and short-term mucosal membrane contact.
A selection of medical device parts printed with BioMed Flex 80A Resin
Read the manufacturing guide for detailed instructions about the workflow for BioMed Flex 80A Resin.
Recommended for:
  • Medical devices
  • Firm tissue models
BioMed Flex 80A Resin prints at 50 and 100 microns on the Form 3B/3B+ and 100 microns on the Form 3BL.
To learn more about the performance or specific material properties of this resin, refer to the Safety Data Sheet (SDS) and Technical Data Sheet (TDS). Always consult the SDS as the primary source of information to understand safety and handling of Formlabs materials.
Required resources
Made by Formlabs:
Printing with BioMed Flex 80A Resin
Washing
Follow the part washing recommendations in the manufacturing guide for the clearest and best possible results. Improper washing can lead to suboptimal mechanical and biocompatibility properties.
Post-curing requirements
BioMed Flex 80A Resin requires post-curing to reach its optimal mechanical properties.
Note:
To post-cure this resin, submerge parts in a glass container of water at least 500mL in size. Parts should be fully submerged with no air bubbles on surfaces.
Follow the post-curing recommendations in the manufacturing guide for the clearest and best possible results. Improper post-curing can lead to suboptimal mechanical and biocompatibility properties.
Additional resources
