Using BioMed White Resin
BioMed White Resin is a medical-grade material designed for a wide range of end-use applications where performance, aesthetics and biocompatibility are critical. BioMed White Resin is USP Class VI certified, and printed parts are validated for long-term contact with skin and short-term mucosal membrane contact. BioMed White Resin is also certified for short-term contact with tissue, bone, and dentin.
BioMed White resin can be sterilized by autoclave, E-beam, gamma, and ethylene oxide.
Medical models and fixtures printed with BioMed Black and White Resins
Note:
To learn more about the performance or specific material properties of BioMed White Resin, please refer to the Safety Data Sheet (SDS) and Technical Data Sheet (TDS). Always consult the SDS as the primary source of information to understand safety and handling of Formlabs materials.
Recommended for:
  • End-use medical devices and device components
  • Patient-specific implant sizing models and molds
  • Cutting and drilling guides
  • Surgical guides and templates
  • Biocompatible molds, jigs and fixtures
  • Anatomical models that can be used in the operating room
 BioMed Black ResinBioMed White ResinBioMed Clear ResinBioMed Amber Resin
Can be sterilized✔✔✔✔
Transparent  ✔✔
Can be polished✔✔✔✔
Compatible with Form 2✔✔✔✔
Compatible with Form 3B/3B+//3BL✔✔✔✔
CertificationsUSP Class VI
ISO 10993-5, -10,-23
USP Class VI
USP <151> Pyrogen + ISO 10993-11 Acute systemic Toxicity Testing
USP Class VI
ISO 18562-1,-2,-3,-4
ISO 13485
Layer thickness50 microns
100 microns
50 microns
100 microns
50 microns
100 microns
50 microns
100 microns
Ultimate tensile strength (MPa)35.745.85273
Tensile modulus (GPa)1.52.02.12.9
Elongation at break (%)14101212.3
Flexural modulus (GPa)1.72.02.32.5
IZOD Impact strength (J/m)24.815.13528
Heat deflection temperature (HDT) @ 1.8 MPa49.452.45465
Heat deflection temperature (HDT) HDT @ 0.45 MPa (°C)68676778
To learn more about the performance properties of Formlabs resins, refer to the library of material properties data sheets.
Required resources
Made by Formlabs:
Printing
Washing
Follow the part washing recommendations in the manufacturing guide for the clearest and best possible results. Improper washing can lead to suboptimal mechanical and biocompatibility properties.
Post-curing requirements
BioMed White Resin requires post-curing to reach its optimal mechanical properties.
Follow the post-curing recommendations in the manufacturing guide for the clearest and best possible results. Improper post-curing can lead to suboptimal mechanical and biocompatibility properties.
Additional resources
